Looking for source for lcolor coded wire
Does anyone know a source for short runs of color coded wiring? I need about 12' of 18 ga in yellow with blue stripe and yellow with white stripe.
www.waytek.com
Sells wire by the foot in many colors. For small quantities you can add the tracer with colored markers. vicrod |
My bad.
Its www.waytekwire.com And they do have a minimum quantity of 100 ft for each color, size etc. Sorry to mislead. Also, www.wiringproducts.com sells small quantities of auto wire. vicrod |
My only other alternative is to strip the wiring out of a harness at the junkyard, but a 12" run of wire is going to be a bear to pull! |
The only place I know of to get striped wire in small quantities is: YnZ.
For what it's worth, they also make some of the best factory reproduction wiring harnesses available. Unfortunately, they don't sell wire smaller than 16 gauge, nor do they sell Yellow/Blue or Yellow/White. So this may be worthless information for you, Buck, but maybe it will be helpful to someone else reading this thread. Making a white stripe on a yellow wire would be difficult.....I wonder if anyone makes a vinyl dye marker similar to a paint marker. If so, that would be the ticket. Good luck.... |
| Converting a ported vacuum source to a manifold source | Scrumgees | Engine | 2 | 08-17-2011 01:09 AM |
| Color coded masking tape, what will they think of next? | MARTINSR | Body - Exterior | 14 | 03-22-2010 10:46 AM |
| pontiac YA 455, coded for 1970 GTO, loading up | Gladis | Engine | 3 | 04-07-2007 11:52 AM |
| Wire Diagram for points,starter,1 wire alt,and distributor | plainhavoc | Electrical | 3 | 04-12-2006 02:13 AM |
| Source for wire harness for 64 Dodge | wheelsup64 | Electrical | 2 | 04-12-2004 11:02 AM |
