Looking to start a project - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2012, 10:00 PM
I don't have a lot of up front cash to build with. A possible start to a rod project has presented it's self. I was talking to my boss today about our old G20 Chevy utility van. It's a short frame van with a 350 Chevy and auto tranny. We are looking at scrapping the van this coming fall since the body is ready to fall off the frame. My thought was with the short frame 1/2 ton suspension 350 and auto tranny it might be a good base to build off of. I was thinking I could find a old 30's 2 door that was missing the front end that I could put onto the frame. The van would come to me really cheap or hopefully free. Would this be a wise way to go or will this frame not work?? Thanks for any input.
Old 05-26-2012, 07:27 AM
delawarebill's Avatar
project
most likely that frame will only fit the G20.. u'll need to modify it to fit a 30's car and may not be worth the time.. IF the drive train is in good cond w/o needing rebuild then it a good parts car. u didn't put down where u are from, but maybe a project on this site will suit your needs...
Old 05-26-2012, 07:57 AM
Wiki Edits: 27
donor drive train
Build a T bucket or lakester, use the engine, trans, rear end, steering column, mabe the gages , master cykinder, find a 40's ford front suspension, or shop speedway, and always consider looking for someone's unfinished project. My niece's boyfriend had a buddy that was selling a started T bucket project for 2 grand, half of what he had in it. I passed it by, too many projects , I picked up a steel T body in decent shape for $ 100, a neighbor told me I could have his old Hay wagon, made from a 20's car, I just to haul everything there away, burn the rotted wood.
Old 05-26-2012, 04:58 PM
I figured the frame would need to be modified to fit whatever I build. Just figured the frame would be heavy enough to handle anything I wish to build plus having the 350 already mounted would make it easy on that part of the project. Have not set anything in stone just looking for input before I do. Thanks for any ideas... Oh from Wisconsin
Old 05-26-2012, 08:02 PM
poncho62's Avatar
Wiki Edits: 5
I think if you look close at that van, the frame is part of the body (unibody).....Take the drivetrain out and use those parts in another car
Old 05-26-2012, 10:13 PM
Hot Rod Has Been
That IS unibody....no frame.
Old 05-28-2012, 05:14 PM
Thanks for that insight on the frame I looked into it today after work there seems to be some sort of frame work the length of the van it was a thought hopefully the motor and drive train will be good for something
Old 05-28-2012, 07:09 PM
Check the block casting. If it's a "010" block (you never know), it's most likely a 4 bolt, and these are pretty sought after because of their high nickel content.
Old 05-29-2012, 08:17 AM
Wiki Edits: 27
check some build threads
Reads Cboys eBook here on HR, "the scratch built hot rod" good info, but his projects would take a while for a beginner, Check out donsrods "basic T bucket build" on the killbillet forum , lots of detailed info and pictures.
Trying to start a project journal.. JJ350 Hotrodders Site Suggestions and Help 2 02-28-2007 05:13 PM
Can't start a Project Journal mutt79 Hotrodders Site Suggestions and Help 2 07-12-2006 07:40 AM
Help...How do i start a project journal? 41chevyman Hotrodders Site Suggestions and Help 1 05-02-2006 11:45 AM
project i want to start Fresh469 General Rodding Tech 2 06-12-2005 12:44 PM
Get to start on my project mattoxcw Hotrodders' Lounge 0 01-26-2004 10:47 AM
