Looking for a steel wheel insert... - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2013, 09:32 AM
S10xGN's Avatar
Gotta love a turbo!
Hi All,
As per this pic, I'm looking for the inner part minus the hoop with a small Ford 5 on 4.5" pattern and an OD between 14 1/4" and 14 1/2". Need one of these for a project. So far, I've had no luck finding one with that ID. Late model Crown Vic's have it but the insert doesn't look "old school"...
Russ
Old 11-22-2013, 10:54 AM
Rick 5150 69's Avatar
Maybe here..Stockton Wheel - Products Heavy Duty - Military - Light Truck - Off Road
Old 11-22-2013, 05:24 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
We used to get those from Speedway as they stock the wheel centers and the hoops as separate pieces for us racers who built our own wheels..Check with them..
Sam
Old 11-23-2013, 08:28 AM
Banned
Wheel Center for Stock Car 15 Inch Steel Wheel, 5 on 4-3/4 - Speedway Motors, America's Oldest Speed Shop
Old 11-23-2013, 09:25 AM
S10xGN's Avatar
Gotta love a turbo!
Originally Posted by Rick 5150 69 View Post
Thanks. I e-mailed them a week ago, and like most online businesses, their e-mails seem to go directly to a "file 13" somewhere. Guess I'll call them Monday...
Sam
Checked out Speedway, but nothing that looks like a stock '60's wheel. If Stockton can't help, guess I can always get a truck wheel and weld in an early small Ford center. This won't be structural, I just didn't want to go thru that much trouble...
Russ
Old 11-27-2013, 10:14 AM
S10xGN's Avatar
Gotta love a turbo!
Anybody got a "plan B"? Called Stockton, they had a chart that shows all the insert diameters and they're all roughly the same size (13.5"-ish). Apparently, the hoop is necked up or down for the tire size. Guess if I really want to do this, I'll have to cut up a truck outer insert and weld in the inner 6" - 8" from a car wheel...
Russ
Old 12-24-2013, 10:49 AM
S10xGN's Avatar
Gotta love a turbo!
For those who care, I got it figured. It came to me in the middle of the night, I just popped up with the idea. No need to cut away just the (too small) insert when I could chop into the hoop and get the exact size I need. Here are pix of the center after cutting, and of it just sitting inside a Weld ProStar on my son's abandoned MCSS project. The edges need to be trimmed & cleaned up a little so it'll fit comfortably inside. Now I just need to get the wheels I will use and build the jig to hold the thermoforming bits...
Russ
ID:	108322   Click image for larger version
ID:	108330   Click image for larger version
Old 12-27-2013, 02:06 PM
Interesting! Love to see how this turns out.
Steel Wheel Paint? Which one? 2vmodular Body - Exterior 8 08-26-2010 07:46 PM
steel wheel bore memphis General Rodding Tech 7 07-13-2008 05:19 PM
stainless steel engine firewall insert de64 Engine 3 08-25-2007 03:57 PM
Steel wheel paint? badriand Body - Exterior 4 06-04-2007 09:25 AM
Cragar wheel insert/bushings jdreher General Rodding Tech 5 01-30-2004 01:21 PM
