looking for suggestions - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2006, 01:41 PM
Rhansen's Avatar
Footbraker
I have a fresh .040 over chevy 350 (factory roller motor), stock internals, KB 3418 (-5cc valve relief flattop) pistons .020 in the hole and some Mr Gasket (.028 compressed) head gaskets (~.048 quench). Due to unforseen circumstances I am considering buying new heads for this motor (orig. plan was to re-use my 882's for approx. 9:1 CR). I would like to use a 64cc aluminum head (edelbrock or similar with <190cc intake runner) but am concerned about the compression (approx 10.2:1 w/64cc) and cam selection.
I don't want to turn the motor past 5500 rpm so will be using a fairly small cam and I want it to run on 89 octane for daily use. Is this doable or should I look at some 72cc chamber heads?
Old 01-04-2006, 04:19 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
I dont think 10.2-1 with 89 octane will be very friendly. Id look for the 72cc heads. Hg
Old 01-04-2006, 05:30 PM
To me since you are going to keep it at low rpms why not use the stock 9 to 1 heads. Put the money somewhere else. ricco
Old 01-04-2006, 09:24 PM
10.2 - 10.3 CR with aluminum heads and .039 quench on 89 octane with no problems. Timing is 37* all in by 2600 rpm.
Old 01-05-2006, 04:00 AM
Oldphart's Avatar
Are we there yet?
Glen242, Please explain your reference to .039 quench. What does this mean?
Thanks.
