Looking for a table... - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2004, 06:27 PM
Last journal entry: Transmission Table
Okay guys, I am looking for a table for my shop.
Basically, what I want is a metal table, that will like a 3 inch lip all the way around, that I can ship up on 3 corners, and drill a hole in the lower corner, so I can tear transmissions and whatever else that will be liquidy, so all the fluid runs out the hole and into a bucket.
We have one at work, dealership, and apparently Grainger has them, but I am unable to find on their website.
If you need me to draw a picture, I could try, but I am hoping someone will have an idea what I am talking about.
Also, by 3 inch lip, I mean basically a 3 inch wall all the way around, not a recess. And all the way around means the 2 short sides, and only one long side.
Thanks in advance.
Old 11-10-2004, 06:54 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Shop Table
that sort of thing one would make for oneself..should be a sheet metal shop around your area that could bend up a box to your dimesions and you can make some legs and frame to support the table..that is what I would do..In fact I could use something like that for my parts cleaning and such..
Make it big and sturdy enough to put a tranny or something of that size on the table..
See if there is an outfit that builds commercial kitchens in your area..they can make a stainless top that could fit your needs..
Good idea you have here..
Old 11-11-2004, 02:19 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Try this.... www.grainger.com
Or you could call Grainger, explain to them what you are after and they could help you out.
For the money, why not just build your own? Probably would be considerable savings.
Kevin
Old 11-11-2004, 07:59 PM
I spent like 45 min on the website before I posted this
Allegedly it is in the Grainger catalog, so, I need to look through a copy and find it.
And it is supposed to be about $120, so, having one built probably wouldn't be cost effective when I factor in the time and engergy, to end up with something that probably won't be any better than what I could have bought.
Now I just have to get a copy of the catalog, or give them a call when I am 100% ready to purchase.
Old 11-12-2004, 02:24 AM
Kevin45's Avatar
I have a catalog in the garage. I'll look thru it later when I get home from work and if I find it will scan it and send it your way.
Old 11-12-2004, 08:07 AM
Thank you. If you want, I can draw one up in paint, if that will help.
Old 11-12-2004, 09:47 AM
Nightfire's Avatar
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
If you buy one at least you know it's level and straight. If you make your own there is potential room for error and the table might not come out level.....this would be the case with my egnineering skills
Mike
Old 11-12-2004, 11:01 AM
MI2600's Avatar
Member# 3287
You can always build one for twice the cost that will be half as good.
-My Philosophy
Old 11-12-2004, 11:02 AM
Kevin45's Avatar
OK...I looked all thru the Grainger catalog and could not really come up with a table unless the top was flipped. Most of the tables in their catalog though come from Edsal. So you may want to check this site Clicky and scroll down until you find the tables and see if any of those would suit your needs. The only other thing that would come into mind would be a table like is used in a cafeteria at schools for washing dishes. If I remember right some of those had a drain area in the corner where you would scrape food off into. So a site that has industrial dishwashing supplies might have something or maybe a site that has to do with butchering. Of course those tables would be stainless steel and I imagine rather expensive. If you have some HVAC places in your area you could get a piece of metal bent up on all four sides and then weld the corners. You could have any size made you want and it would not be that bad pricewise. Then all you would have to do is order some industrial bench legs which are around $55 in the Grainger catalog. Just a few options to look at. Keep us posted.
Kevin
Old 11-12-2004, 11:41 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
Why not use a piece of 16 ga. sheetmetal with sides turned up and corners welded. Have the fabricator "X" the bottom. Weld pipe flanges in the corners for legs(Or drill/silicone). Weld a bung in the center of the X, drill, and install a ball valve. Done. 16 ga. should be plenty, considering the side would be under 24x36 or so. I would guess your cost would be less than $100.
(Or use 6" pipe nipples and set it on your regular bench, so its not in the way all the time)
Old 11-12-2004, 07:57 PM
Here ya go...you need something like this:
http://www2.northerntool.com/product-1/19880.htm
Oh yeah...the price...dang.
Old 11-12-2004, 08:12 PM
Wiki Edits: 3
Price yeah
Owwwwww..think I woudl make something for this job..lots of good ideas came up..
Buying stuff like this leaves nothing for hot rod parts..
OMT
Old 11-12-2004, 09:47 PM
Thanks guys for the assistance. I am still not finding what I am looking for, but if I can find my digicam, I will snap a pic to see if that is of any assistance.
I am going the search for a manufactor name on the one we have, see if I can find anything from that.
I'm not the fabricator type. It seems like anything I try to build always flops, so, building one is definitely out of the question.
Old 11-17-2004, 09:26 PM
fourbyfourblazer's Avatar
Chopper Builder o<>\o
Last journal entry: Dash Removal
I discovered this site that may have what you are looking for.
bcwengineering.com
Transmission Repair Drain Table
or
WorkTableWorld.com
Old 11-21-2004, 02:39 PM
I like the first one, I might need to give them a call.
The second place is way too expensive for me.
I had my dad build me one, not really what I wanted, but it should suffice for now. I will try to take pictures later this week.
