looking for a trans sensor to trigger an electric fan - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2010, 07:15 PM
In my truck, I have no space in front of the rad to mount a trans cooler, so I will mount it under the floor. I will therefore have to use an electric fan with it and I need a sensor/thermal switch to trigger the electric fan when the trans fluid gets up to a certain temperature.
My problem is where to find this!?! I know B&M has one but only sells it as part of a whole kit (switch+cooler+fan): I just need the sensor/switch!
Any thoughts?
Thanks!
Old 04-01-2010, 09:13 PM
Shelby1's Avatar
Steel Dreams
I used one from NAPA that was for a electric radiator fan.Mounted the sense tube in the fins of the cooler .The unit was adjustable and I had to play with the adj till I got to come on at the right time.Drove the truck 2 years and never had a problem.I can't give you the part number as I no longer have the truck but it was the only adjustable one they had........about 25 bucks IIRC
Good Luck
Kenny
95 Mustang 2 speed electric fan & 351? macx Engine 3 09-01-2007 01:13 PM
Electric fan wiring? Boostedpimp Electrical 13 12-12-2006 10:44 PM
Electric or Mechanical fan? Which do you prefer? Z-Money Pit Engine 13 11-15-2005 05:44 AM
Fan module/relay .....86 Trans Am KeithB123 Electrical 1 11-10-2005 06:58 PM
Electric Cooling Fan Mounting subman17 Engine 2 10-22-2004 12:15 PM
