Looking for a under dash compact wiper motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2008, 12:31 AM
My car is right hand drive and the rocker cover on my sbc fouls the wiper motor which is also on the right hand side. I have no option now than to run the wiper system under the dash. I found a compact simple looking rear mount wiper motor called a 'monster guts' of all names, but it appears their factory has had flood damage or something and there is none available for the rest of this year. Anybody know of another motor I could use? Other option is the cable type systems, how good are they and are they hard to set up?
Old 10-09-2008, 12:36 AM
JeffB's Avatar
To the rescue!
Check the H.A.M.B. technical from yesterday there is a step by step thread there with pics of each step,I think he used an S-10 blazer rear motor (very compact)
Old 10-09-2008, 12:58 AM
Cool thanks for that, but um what is H.A.M.B?
Old 10-09-2008, 10:30 AM
GaryD's Avatar
The H.A.M.B. is another of the great forums out there for hotrod info and discussion. Here's a link.
http://www.jalopyjournal.com/forum/
Gary D
JeffB's Avatar
It's a website,go to:www.jalopyjournal.com and click on H.A.M.B.
Old 10-09-2008, 10:58 AM
powerrodsmike's Avatar
Wiki Edits: 161
I've used the cable type a bunch of times, Specialty power windows is the manufacturer.
They are fairly easy to set up, can be mounted where ever you want, (within the reach of the cable, and routing so you don't bend the cable housing under a 3" radius)
The kits have 2 speeds with an optional intermittant setting. They can be set up with different sweeps and park positions as well.
They are somewhat noisy, especially if the cable is long.
Later, mikey
BE different....ACT normal.
Old 11-07-2008, 01:03 AM
compact wiper motor
I ended up looking at a few jap cars and could have used any of them pretty much, they are all pretty small. Think I will use one off a nissan skyline, very compact and easy to mount.
Old 11-07-2008, 03:12 PM
302 Z28's Avatar
Mighty Wiper, self contained and super easy to install.
Vince
Old 11-07-2008, 06:58 PM
under dash wiper motor
Vince
Thanks for that, but that looks to be like a back and forward motor, would that be right? I just need a normal round and round type.
Cheap GM HVAC blower motor fix. M&M CUSTOM Electrical 8 05-17-2009 11:10 AM
wiper motor wiring 37 plymouth coupe Electrical 4 07-27-2007 11:30 AM
Can you identify this aftermarket wiper motor? RodFather General Rodding Tech 2 06-25-2006 09:52 AM
Windshield Wiper Motor - '30 Model A StripeUSA General Rodding Tech 2 11-04-2005 04:10 PM
hidden under dash wiper motor trucking95 Body - Exterior 1 12-01-2002 04:05 PM
