Acually this started as a Daily driver had a 305 with 700r od 331 gears ,then i built thus engine a new crate motor 030 over bore .250 over stroke aka 496 ,put comp cam 280,roller rockerss and comp roller chain and push rods .then trick flow alum heads 225/188 -113cc saved 70 lbs alum water pump no hp gain but 19 lbs off the front alum intake with tripowerr 3 holley 500s msd ignition & dist sanderson 3 " headers flattop kb pistons so the 500 est is conservative ,now my son is doing a frame off paint job changing to porsche guards red he is doing it for advertising, his body & restoration shop so price is right ,Probably will see limited use now ,i will be installing 4 link adjustable when i get it back
