looks like a 383 - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-19-2012, 09:08 PM
vinniekq2's Avatar
just to be in the middle Bdad,I see 470 HP maybe?that cam would be a decent street piece.
  #17 (permalink)
Old 12-19-2012, 09:10 PM
vinniekq2's Avatar
what gear ratio do you like? That cam does not need a very big converter.My old Camaro was similar to what you are thinking,except I used a scorpion intake
  #18 (permalink)
Old 12-19-2012, 09:15 PM
I have options for gear....young lad at my shop has a 456 with spool center section I can use, yes for track only with the spool....but I haven't bought a gear as of yet....would like to cruise at 3000rpm at 100kph and a 31" tire.....
  #19 (permalink)
Old 12-19-2012, 09:28 PM
vinniekq2's Avatar
4.56 gear with 31 tall tire at 3,000=97kph
what tires do you have that are that tall?
  #20 (permalink)
Originally Posted by F-BIRD'88 View Post
440HP +/-15 HP 110MPH 1/4 Not enough gear ratio. Not crazy about the head choice. There are better choices for $1K.
Flow master mufflers suck. Pick better mufflers and you will go faster.
12.7@110. can be 12.0 solid high 11's @115+ with better choices and more gear. Same money.
Watch the final assembled compression ratio. A little too much is a LOT TOO MUCH. Kinda like tighening the end cap on a pipe bomb, or hanging your toes off the edge of a cliff.
a real 10.5:1 gets it done on 94 octane. I like to keep the measured cr under 11:1 actual for street motors.
If you do want a real deal 500hp 383, thats not it. but a few changes will get you there , for the same or very near the same money. ref: 500hp ='s mid 11's@116-117MPH in that car.
you will need a better converter and more gear.
I have the option for 72cc heads as well, if I have the block machined tyo zero deck clearance and a .028 head gasket this looks like 10.48.1 ......I may look at the profilers if my Guy can get them, if not the IK200's were an option but not sure if they can be had for 72cc and I believe there at least a couple hun more....what other alum head can I look at for 1000-1100 bucks at my door with a 72 CC chamber....kinda rules out summit or jegs house brand due to shipping etc....and I know you want to see more converter but this is what I have for now.....gears aren't completely decided on yet tho....and what about a 1.6 rocker with that cam choice?
  #21 (permalink)
Old 12-19-2012, 09:29 PM
31/18.5/15 Mickey Thompson sportsman pros....
So 456 looks ideal for me and where and how I drive....
  #22 (permalink)
Old 12-19-2012, 09:38 PM
vinniekq2's Avatar
what were the flow numbers on the 1k heads?
I ran 11,9s with 2.02 angle plug heads/cast iron.
  #23 (permalink)
Old 12-19-2012, 09:40 PM
F-BIRD'88's Avatar
Yada Yada Yada
a .028" gasket will not work with a 0 deck clearance. Too tight.
any all shipping from Summit and Jegs, Flatlanders, Competition Products,,, and Factory Direct from Profiler, Brodix, Comp, Lunati etc
GeT the stuff ground shipped "shipped to the Border" go pick it up yourself and import yourself. (13%HST)
You can get a "account" with them usually a flat rate. Or pay a flat fee per package. For receiving/holding your packages, for pickup.
You just drive down and pick the stuff up declare, and pay HST at the Canadian border.
its goof proof simple to ground ship to the border and import the stuff your self.
Ogdensburg, New York (serving Ottawa and Brockville area) | Ship to the Border
This is Closer to you than "your Guy" in Montreal. Now you can shop around.
If I was going to start with a Dart cylinder head I would start with the 215 cc port Dart or the 230cc port Dart head ( for power)
  #24 (permalink)
Old 12-19-2012, 09:47 PM
any all Summit and Jegs and Direct from Profiler, Brodix, Comp, Lunati etc shipping.
Ge the stuff ground shipped "shipped to the Border" go pick it up yourself and import yourself. (13%HST)
The summit house brand I like and yes, I actually have a friend in ogdensberg so could have them shipped there, unfortunately I don't have a passport so I would have l have them picked up but that's still doable....
  #25 (permalink)
Old 12-19-2012, 09:50 PM
Tried copy and pasting from a 9 page thread on the Bullet but my tablet hates me so it didn't work....the numbers were dissapointing out of the box but got significantly better with some minor grinding....
  #26 (permalink)
Old 12-19-2012, 10:09 PM
F-BIRD'88's Avatar
Yada Yada Yada
Dart heads in general are very good quality thick high perf castings. But they do need a good going over to get them up to snuff from out of the box , as cast form. The SHP head is not the same as the Platinum,, Pro 1 stuff.
I would look at some other stuff before you buy. The nice thing is you have lots of choices and all winter to research.
Any thought of using a spool on the street is a deal killer. Same with the flowmaster crap mufflers .
These will kill the real power more than any thing. There are way better mufflers. Especially if you like to and plan on "Driving" your car.
  #27 (permalink)
Old 12-19-2012, 10:12 PM
vinniekq2's Avatar
Calculate HP from Trap Speed
Vehicle weight in pounds (including driver)
lbs
Trap speed at end of 1/4 mi in m.p.h.
m.p.h.
You are making : HP at the rear wheels and HP at the flywheel*.
looks like tech was right on the money
  #28 (permalink)
Old 12-19-2012, 10:14 PM
vinniekq2's Avatar
I was using 3950 pounds total weight
110 MPH from fbird
493 HP
  #29 (permalink)
Old 12-19-2012, 10:20 PM
F-BIRD'88's Avatar
Yada Yada Yada
You realize you are getting real close to the price of a more power full simple supercharged 350.
you already have many of the required parts for this low buck simple blown 350.
  #30 (permalink)
Old 12-19-2012, 10:21 PM
Originally Posted by bygddy View Post
Are you kidding me?.?.???? On pump? For under 4g's.....any idea how happy that would make me lol......would using 1.6 rockers help the cause assuming the valve train is up to it? And that I can work the heads to support the lift?
you won't get anywhere near 500 with those heads and cam, sorry to break the news to you.
if you want to get closer, step up to a set of afr 195cc heads and go a little more intake duration.
whats better 400 crank or a 383 crank in a 350 sbc when trying to build a 383? onlychevy Hotrodding Basics 14 12-28-2012 07:27 AM
383 stroker v.s. 383 chrysler ...the end mcharger440 Engine 58 12-07-2012 08:16 AM
help my 383 OMARS67 Engine 7 06-18-2012 09:49 AM
NA 383 or 177 WEIND 383-Vote bigalow Engine 5 11-16-2011 04:44 AM
383 Stoker vs 383 Chrysler Jag Daddy Engine 100 08-14-2008 11:48 AM
