Loose Baffle? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2002, 03:19 PM
dion's Avatar
72 Chevy Cheyenne
Post Loose Baffle?
My driver side pipe is making a blup blup sound with small chirps, is it a loose baffle in my muffler? Maybe a miss somewhere in the engine? The carb, wires and plugs are new.
Old 09-14-2002, 03:50 PM
NAIRB's Avatar
Post
It could be a baffle, it could also be a miss. If the timing is a little fast it will make a sound similar to this.
Old 09-14-2002, 05:56 PM
woodz428's Avatar
Troll Hunter
Post
Diagnosis by someone elses' sound definition is always a little tough, but if it is only on one side it probably isn't timing. How many miles on the engine? Bad valves on one head could cause a weird sound as well as intake leak on that side. More diagnosing is needed, Compression on the cyl., power balance check , stuff like that.
Old 09-14-2002, 06:09 PM
dion's Avatar
72 Chevy Cheyenne
Post
Engine only has 3200 miles on it.
