The hardest part is taking off the handles. Take a picture of the position of the door handles before you take them off. Does yours have clips like these holding the handles on? If so, you need a Lisle 35200 Windshield molding/Door handle clip pliers. CLICK HERE Reach in with the pliers and pull the clip out and the handle will come right off. Put the clip back in the handle and when you're ready to put the handle back on just push it on and the clip will catch a groove on the door handle stud. After the handles are off, remove any screws that are visible holding the door panel on, remove the armrest if there is one, and then gently pry up under the door panel with something wide like a heavy putty knife and pry the door panel clips out of their holes.
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
| Recent Interior posts with photos |
| loose distributer gear... | DENCOUCH | Engine | 5 | 01-31-2010 06:18 PM |
| Balancer loose on crank | powerrodsmike | Engine | 22 | 06-13-2009 12:15 AM |
| TH350 sun shell, loose... | CamSweet | Transmission - Rearend | 2 | 01-31-2008 04:23 PM |
| loose input shaft | fireguy | Transmission - Rearend | 2 | 11-26-2004 07:34 AM |
| loose intake bolts & oil fouled plugs | 68GEETEE | Engine | 1 | 09-26-2004 03:56 PM |
