loose HEI pickup coil - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2006, 11:27 AM
Had my HEI apart to fix the advance, I noticed the pickup coil had some free play. The coil plastic shell is keyed to fit into the unit, but the keyway is larger and allows more than 1/32" of rotation. Is that normal? I know it's not much movement, but seems that it could potentially cause engine vibration, no?
Thanks,
-Michael
Old 11-01-2006, 04:08 PM
To answer my own question, it turned out that the loose coil was causing some rough engine operation. Being cheap I didn't want to spring for a new coil since this one worked... so I put a dot of silicone in the keyway to keep the coil secured to its housing. I had forgotten that the pickup coil moves with the vacuum advance, so that extra 1/16" free play was a problem. Accelerates MUCH smoother now, and just glides down the highway.
Odd problem, I might have never found it either. of course something as crazy as a loose coil would only happen to me
-Michael
Old 11-01-2006, 04:50 PM
johnsongrass1's Avatar
Race it, Don't rice it!
I've had em go bad. Caused me a few races and a lot of headaches.
How Does This Stuff Work? docvette Electrical 3 06-18-2006 04:00 AM
65 Chevy Firing Problems EazyDuzIt102 Engine 24 10-09-2005 10:12 PM
Junkyard HEI Thom Laybourne Engine 2 09-08-2004 04:46 PM
GM HEI MSD 6AL- What coil do you run? YtseJam Electrical 5 12-06-2003 06:20 PM
HEI help...before I go crazy EricTopless68 Camaro Engine 13 09-29-2003 10:08 AM
