Early Hemi rocker shafts Hotrodders.com Free Speech Parts Auctions
Bid on a part, or auction one off -- help us defend against a frivolous lawsuit, and protect free speech online.
Click here for details.
Parts currently up for auction: 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, Early Hemi rocker shafts, "Power Rods" billet air cleaner top.
Model A Ford headlights
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 05-07-2005, 07:02 PM
Doc68 Doc68 is offline
Loose King Pin
'28 Rod with 4 inch drop tube axle; 49-54 GM spindles.
Was about to drive the rod today when I noticed the passenger side king pin sticking up over an inch above the spindle. Yikes!! How did that happen?!
Inspected both king pins. I have had very little experience with kings pins so I'm not sure what is missing here. They both have thin metal caps on top of the spindle covering the king pins. These are easily removed. On the driver's side bottom, there appears to be some kind of metal cover inside the spindle holding the king pin in place. The passenger side spindle is missing this.
I can tap the passenger side king pin up or down, but can't figure out what kind of snap ring or other device fits top or bottom that prevents the king pin from moving. Obviously the passenger side is missing something as it does not have that fitted metal cap on the bottom of the spindle. When I tried to tap the driver's side spindle up, won't move because of the fitted cap.
Help. I need a quick lesson in king pins and what keeps them in place because the passenger side wants to leave the spindle!
Old 05-08-2005, 12:33 AM
hoodoo's Avatar
hoodoo hoodoo is offline
Self-made nobody.
re: Loose King Pin
According to the photo located at this link, 1942-47 Chevy front axle , there should be what they call a "Kingpin Lock Pin" (#13 in the photo) which secures the kingpin. Even though the photo is for earlier year Chevies, it should be about the same for your tube axle. That's the same method used on my former '37 Plymouth so I believe it is a common design.
Old 05-08-2005, 02:22 AM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Yup One of those Moderator's
 OneMoreTime's barnstar
Wiki Edits: 3
Kingpin lock pin
Since I am a ford guy not sure on the chev spindles..on the fords the little top and bottom caps just hold a grease fitting and don't do squat about holding the kingpin in place..
There is a kingpin retaining pin that goes in the center of the axle which lines up with a slot milled in the kingpin..sounds like yours is missing..
Thsi is a special tapered "bolt" that is held in with a nut..look at the other side to see if this is true on yours..
One thing to check is to remove the spindle and see if the axle end is egged..check that before reinstallation..
Sorry about the oops but good you caught it..
OMT
If it don't work it ain't pretty!!!!
Old 05-25-2005, 08:51 PM
billg_69gmc's Avatar
billg_69gmc billg_69gmc is offline
king pin info
Luckily I am swapping out from 6lug to 5 lug and the king pin issue is sorta fresh in my mind.
The two "cups" on top and bottom are king pin bushings. These are supposed to be pressed in. If one has fallen out that is bad, maybe a symptom of another problem. As mentioned by another poster, the retaining bolt secures the king pin in place. Without that you could have a failure since the king pin can come out.
Safest bet is to dissassemble that steering knuckle and replace the crush bearing, bushings and lock pin. A bit of locktite on the end of the threads of the lock pin bolt will keep it from vibrating loose.
The same lock pin design is used on the front of the rear spring shackles of my 59 chevy.
Be mindful that your bushings have to line up with the grease fittings if they are of that nature. Usually you have to puncture the bushings and pry them out. Having them loose is not good. I would definitely check to see if any damage happened to the joint that the king pin is part of... hopefully you got lucky and caught it early.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Loose King Pin"
King pin won't take grease Slickriffs Suspension - Brakes - Steering 12 08-16-2004 08:52 PM
53 Chevy King Pins TommyC Suspension - Brakes - Steering 6 06-04-2004 12:13 PM
king pin for 1940 chevy Keven Suspension - Brakes - Steering 5 03-06-2004 05:44 PM
changing a 4 pin distribture to a 7 pin geno Engine 5 01-19-2004 04:31 PM
The King of Trid Kevin45 Hotrodders' Lounge 3 12-09-2002 07:12 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
