Loose Rockers - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2013, 05:28 PM
Russell.K's Avatar
Loose Rockers
Hi, I have a chevy small block 350 out of a 75 Camaro. Everything is stock on the engine. I believe they are hydraulic lifters in the engine. When i tighten the rockers till the pushrods don't move then go another 1/4-1/2 turn, they seem fine and tight. But after i go through them all, they get loose again. The nuts holding the rockers down don't back out at all and the engine doesnt even have to be running to loosen them. Do I just keep tightening them or what? Thanks
Old 06-19-2013, 07:24 PM
BOBCRMAN@aol.com's Avatar
Common with older stuff. The lifters are just leaking down to zero lash. Do not re-tighten.. they will run fine..
Old 06-19-2013, 08:43 PM
You are making sure the lifter is on the base circle of the cam when you're adjusting them? Just checking.
Old 06-19-2013, 09:00 PM
Russell.K's Avatar
Yes I made sure its on the base circle
Old 06-20-2013, 07:42 AM
In order to set the lifter preload, the lifters must be on the base circle of the cam lobes. Find zero preload by up and down movement of the pushrod before adjusting 1/2 to 3/4 turn.
First, get a small artists paint brush and white paint. Mark off the harmonic damper in quarters from 0 timing mark, #1 piston TDC on compression stroke.
#1 TDC...........set int. / exh. on #1
1/4 turn CW....set int. / exh. on #8
1/4 turn CW....set int. / exh. on #4
1/4 turn CW....set int. / exh. on #3
Continue 1/4 turn and set preload in that manner according to the firing order. That will guarantee the lifters will be on base circle (overlap) of cam lobes when they are adjusted.
Firing order: 1 8 4 3 6 5 7 2.
Old 06-20-2013, 08:56 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
OR the cam is going flat.Hope not.
you can adjust with engine running back off rocker until click is heard then tighten rocker I/8 turn at a time untill you get 1/4 to 1/2 turn .only tighten 1/8 at a time will give lifter time to pump ,will make a mess unless you have rocker arm clips.
Old 06-20-2013, 10:39 PM
lifters could be weak bleeding off or it could have a set of antipumpups in which case god help you! or like the previous comment flat lobes?
Old 06-21-2013, 02:00 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Totally normal. Do not adjust twice.
Adjusting hydraulic lifters.
The Following User Says Thank You to cobalt327 For This Useful Post:
sweetlil66 (06-22-2013)
Old 06-23-2013, 07:55 PM
Mine did that. My rocker studs where pulling out just lay a strait edge on them and check I always do
Old 06-24-2013, 05:27 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The difference here is the engine wasn't run between checking the preload. In Russell.K's case, it's bleeding down the lifters from the valve spring pressure.
Old 06-30-2013, 06:49 PM
Don't worry about how they feel after preload. They will bleed down. As long as you set them the proper way [ and this is the key!!!!! ] just start it up.
Old 07-02-2013, 06:29 PM
Russell.K's Avatar
Thanks guys for the replies!
chevy small block, rocker arms
Loose rockers, valve adjustment david-b Engine 12 09-08-2011 09:59 AM
Loose rockers, bad? steveyb4342 Engine 8 04-15-2007 06:40 AM
Rockers keep coming loose!!! Siggy_Freud Engine 14 03-01-2005 04:58 PM
roller rockers rattling loose after engine swap twisted91 Engine 8 01-02-2005 09:21 PM
loose rockers 67bird Engine 2 01-21-2004 01:59 PM
