Loose shift linkage? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2007, 08:52 AM
Mertz's Avatar
I have a 72 C20 with a 350 auto that was just rebuilt. The linkage is very loose and getting looser. I have to shift well past drive to engage drive and then move the lever back to have the indicator in the right place. I looked in my manual but there is nothing that helps. Is this a problem with the linkage on the column or on the transmission or what? The linkage levers under the hood seem fine.
Old 02-06-2007, 10:12 AM
poncho62's Avatar
Wiki Edits: 5
Dont know exactly how yours goes, but check to see if there are bushings at the joints of the linkage. If each is worn a bit, it adds up to a lot. Also, there is probably a pivot on the frame down by the tranny....My Blazer has a nylon bushing in there that wears causing looseness.............
Old 02-06-2007, 01:43 PM
There is a grommet or bushing of rubber in the shift lever on the steering column that the shift link installs in with a cotter pin. These are available at your Chevy/GMC dealer for about $3. You may also have a nylon bushing at the shift link on the transmission which you should replace as well.
Old 02-06-2007, 01:48 PM
Mertz's Avatar
The trans was rebuilt by a very good machinist who only work on chevy trannys. The shifting lever seem tight. What do I need to do to get to the column bushing?
Old 02-06-2007, 01:54 PM
The column bushing is located in the shift lever at the base of the column where the shift link is mounted.
Header collector in way of column shift linkage Warrant Engine 4 08-29-2006 12:26 PM
best way to adjust shift linkage? lemans-tom Transmission - Rearend 2 09-08-2005 02:54 AM
Shift Linkage starman141b Transmission - Rearend 3 12-22-2004 06:19 PM
Camaro shift linkage problem chevcamz28newbie Transmission - Rearend 2 07-21-2003 02:01 AM
shift linkage dusterbd Transmission - Rearend 5 09-15-2002 11:00 AM
