loose/sloppy steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2003, 10:39 PM
billybob_v10's Avatar
I have a 79 F-150 with a 460 and C-6 tranny. The steering has a lot of play in it and is sometimes a little hard to control at highway speeds and even in town. Is there any easy way to adjust any linkage to tighten it up a little? Or do I have to replace my steering arms? Thanks in advance, Billybob
Old 08-10-2003, 10:48 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
if its manual, there will be a lock nut with a set screw on it, go to the knowledge base, and do a search on steering adjustment, there is a particular way to adjust this, as if its done wrong, you can shorten the life of your steering box, and yourself....
you might look and see how worn your radius arm bushings are, as they will cause 'walk' going down the road...
and if the rubbers are shot on your tie rod ends, you'll more than likely have a little slop there too, as the tie rod is probably wore out..........
Old 08-10-2003, 10:53 PM
its an automatic...
Old 08-10-2003, 11:01 PM
manual or power steering???
Old 08-10-2003, 11:17 PM
Power steering
