Loose steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2008, 03:26 PM
Loose steering
I have a 74 cj5,with the engine off I can turn the lower steering shaft back and forth about have way and the part going into the power steering box is very loose.Could it be the bearing or the gear box?
Thanks for reading.
Old 04-17-2008, 06:45 PM
cboy's Avatar
Last journal entry: Finished
Can you get a vice grip on the input shaft of the steering box? If so, try just moving the input shaft back and forth while you (or someone else) holds tightly to the pitman arm. If you can rotate the input shaft 1/8 to 1/4 turn without the pitman arm moving...odds are it's a problem in the steering box. If the box itself is tight (pitman arm moves immediately when you rotate the input shaft) then I'd start looking elsewhere in the steering linkage.
Always learning...and sharing what I've learned.
Old 04-17-2008, 07:03 PM
Will do,thanks
Loose steering trenchdog73 Suspension - Brakes - Steering 5 08-31-2005 02:42 PM
78 chevy truck steering very loose chevy2kss General Rodding Tech 10 02-20-2004 09:00 AM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
Power Steering fluctuates between hard and loose. 72Nova Suspension - Brakes - Steering 4 05-25-2003 01:52 AM
Loose steering even though steering box is relatively new? 72Nova Suspension - Brakes - Steering 8 05-14-2003 03:09 PM
