Loose Steering Column With a Werid Twist - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2011, 12:40 PM
seawolf18's Avatar
I was helping my buddy tear down his tilt steering column tonight, in his 81 Chevy pickup. The column was so loose that when he would put it in park, the key switch would rotate to the 12 o'clock position.
We got the column torn down to the infamous four bolts that are usually loose, but found out they were not loose. After scratching our heads for awhile, we found what looks like a break in the metal piece that the bolts screw into.
I have fixed quite a few of these over the years, but have never run into this problem. I am amusing the best thing for him to do is find another column in a bone yard? Has anyone else had this problem? I have also included a picture of what we are looking at.
Old 09-13-2011, 02:08 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
looks like another column is in order....moving to general rodding tech..
Sam
Old 09-14-2011, 10:48 AM
seawolf18's Avatar
We are looking for a different column, but it is getting harder to find these trucks in the bone yards. That and the price of steel is around $200.00 a ton, so everyone is crushing everything that is old heavy and has lots of steel in it.
Old 09-14-2011, 11:10 AM
Wiki Edits: 3
Try www.car-part.com that is the online wrecking yard interchange and someone may have a suitable part for you..
Sam
Old 09-14-2011, 09:42 PM
techinspector1's Avatar
Wiki Edits: 326
Remember to look for GMC's, same column. Probably the same on Blazers and Suburbans. Motorhomes and vans might have the same column also. if it's a little too short or a little too long, take the patient to surgery.
Old 09-15-2011, 04:48 AM
willowbilly3's Avatar
Last journal entry: Body mods
Vans are not the same. If it is the ends of the tube that are torn out, I have taken those apart and welded them back into shape (with lots of die grinder work) A good column would be easier. Yep, lots of those old trucks getting crushed, I just hauled one in last week. Parts prices are soft on gas guzzlers and iron prices high. It brought over $500 across the scale, not worth the time to nickel and dime parts from. Good luck finding one. Maybe cruise the back alleys and trailer courts, every wannabe kid mechanic has tore apart an old chevy pickup or camero and few ever get reassembled.
loose steering? ponchopower48 Suspension - Brakes - Steering 4 11-03-2010 08:25 PM
Loose steering wheel on GM tilt column, how to fix ?? NASCAR314 Suspension - Brakes - Steering 17 01-11-2009 07:20 PM
Loose Tilt Column dsmith1279 General Rodding Tech 3 07-22-2008 06:45 AM
Loose steering redneckhotrods Suspension - Brakes - Steering 2 04-17-2008 07:03 PM
Corvette steering column loose woody51 Suspension - Brakes - Steering 4 01-28-2005 03:29 AM
