Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Loose steering even though steering box is relatively new?
Old 04-30-2003, 06:52 PM
slider in wa's Avatar
slider in wa slider in wa is offline
Slider in Wa.
Post
Keep it simple. Frist check your air psi in the tires!! Take and jack up the front of the car,(no weight on the wheels)grab your 5/8s wrench ,loosen the jamb nut on the sterring box. With your screw driver or allen wrench(as required) turn in the worm gear until it seats. Then turn it out 1/8th to 1/4 turn.Lock down the jamb nut. Then look at the brakes. Simple stuff frist. My two pennys worth. But let us all know what you find out. I would think if you just rebuilt the front end and had it aligned, they would have adjusted the sterring box. However, stuff happens!!!!
Slider in Wa.
