Does it have tilt built into it?
I know they were notorious for the 4 bolts coming loose making the tilt loose. Don't know if the aftermarket design is the same. |
There is also a bearing up top that could be worn.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod. |
I could be a number of things and all of what has been mentioned. I know a common problem with steering play is the coupler. The couple is a round disc looking thing that connects at the end of the steering shaft and connects to your steering box. They are rubber and they rot and break. Most people don't look at them and assume they are good because they look good. Take it off and see if the rubber is cracked or split.
lower cover in steering column.
can you detail what lower cover you are referring to? thanks. |
Just going by memory here, but it would have been the cover on the column below the wheel. This was a stock unit so your's may be completely different. There will be a way to get to them, you'll have to look.
Can you post a picture? They usually have some bolts under the wheel that get's loose.
If I remember right,You may have to undo the blinker set up,And just lift it a little to get to the bolts,It sound's harder then it is. Good luck.
If its the same as the column in my Fiero here os a link
http://www.fiero.nl/forum/Forum2/HTML/088020.html |
Just went take my flaming river column a part,It's made a little different then the factory one's that has the bolts under the blinker's.You need to post a picture so we maybe able to tell what column you have..
| steering wheel | raideral | Interior | 6 | 12-14-2007 04:19 PM |
| What's the smallest wheel offset for street rod... | 71gtx | Suspension - Brakes - Steering | 8 | 12-02-2007 06:02 PM |
| Street Rod Engineering Stub for 50 Shoebox | 8cuda | Suspension - Brakes - Steering | 1 | 09-13-2007 11:45 PM |
| Street Legal TV to Broadcast Video from NMCA Super Bowl Event at Route 66 | nmrajames | Hotrodders' Lounge | 0 | 07-26-2006 09:53 PM |
| Steering wheel decision help | guba_unus | Suspension - Brakes - Steering | 2 | 02-12-2006 10:21 AM |
