IMO a fuel block is a poor place to trust an epoxy to keep sealed long term.
If the block large enough to go to the next larger pipe thread, I would go that route. |
It's highly unlikely JB Weld is going to seal fuel coming past threads. There are sealants specifically sealing pipe threads but if they are "loose" or damaged then it probably isn't going to help. Your best bet really is to return the fittings you have and move up to 1/4" fittings. Or buy a new fuel log.
You might be able to get it to seal for a while but you're just going to be sitting on a fire hazard waiting to happen. |
JMO, I have tried JB weld around and on fuel fittings before and it will only last for alittle while then the fuel will start flowing back out again. Don't use it where fuel is involved IMHO.
Cole |
Would pipe solider (sp?) and some careful heat work? I know, I know, not right according to Hoyle but it doesn't sound like political correctness is an issue. Might work, might not. Just another idea. Take it for what its worth.
![]() http://www.westmarine.com/1/1/3642--...1-4-x-1-8.html |
sealant
My overall first suggestion would be to make or buy a new fuel log. Use sealant on the pipe threads. You do NOT want any leaks in the fuel supply system. FYI: Most fuel logs were made from a soft grade of aluminum and used 1/8" NPT. Often when the fuel line nipples were installed, they were done DRY and would leak as a result despite the tapered fit of the threads. Then the fittings would be overtightened in an attempt to 'seal' the leak. This would stretch the threads and cause a loose fit and would leak. When fitting tapered pipe fittings together, they should be snug with about half of the male threads still exposed. If a sealant has been applied to the threads, an additional 1/4 turn should complete the seal and not strip or over stretch the threads. |
Loose threads in fuel block
Fixing the one you have in parts and time would be more than 60 bucks, maybe you don't care if you drive around in a bomb, no pun indented, but the people with you or around you might. Bob |
| Fuel Block mounting on firewall... | 454headache | General Rodding Tech | 7 | 08-29-2010 12:45 PM |
| big block fuel pump? | jake_arcticcat | Engine | 3 | 05-29-2009 11:49 AM |
| Chevy small block threads | lindermat | Engine | 3 | 07-31-2007 10:56 PM |
| supercharged big block fuel delivery | mad55chevy | Engine | 2 | 12-24-2006 10:33 AM |
| Chevy 350 block stripped threads....help | flyin99 | Engine | 7 | 11-05-2006 08:53 PM |
