Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Loosing voltage.
Old 10-17-2003, 09:14 PM
78SilverShark 78SilverShark is offline
Vetter
I'm glad you found the problem. Yes, when you are having electrical problems, the best thing to do is first check your grounds and make sure they are all functioning and hooked up properly. My friend was working on his '66 Impala and he just did a total rebuild and when he dropped the engine in with the new starter and coil, it wasn't working. Turned out that he had his ground connected in the wrong manner.
78SilverShark
