losing weight - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2005, 10:25 PM
losing weight
i might be in the wrong forum, but whats the best way to lower wieght on my car?
Old 08-06-2005, 11:02 AM
willys36@aol.com's Avatar
Wiki Edits: 21
There is no way to answer your question. What make and model car do you have? The answer depends heavily on that information. Then you need to be clear how far you want to go with this. Is it an all-out drag racer or a red light racer/daily driver? How much creature comfort do you want to keep? It is possible to get any car down to 1500# but it would be nothing you could drive for more than 1/4 mile.
Old 08-06-2005, 08:35 PM
i have a 92 camaro. I drive it pretty often. but as comfort goes, i dont need it. i would like to keep the passenger seat though. everything else can go.
Old 08-06-2005, 11:05 PM
Wiki Edits: 21
Hollow out the doors and replace all windows with 1/8" plexiglass screwed in place (only glass left is the windshield), cut out the fender wells, replace front seats w/ 2 fiberglass bucket seats, cut out the trunk and rear fender wells and replace them with thin aluminum sheet metal, rip out everything under the dash and get a small wiring harness for just the essentials, Take the dash cover off and replace it with aluminum sheet metal, get fiberglass fenders and hood, rip out the front suspension and replace it with a tubular axle & parallel leaf springs with the drop you desire, take out stock tail lights and replace w/ red 1/8" plexiglass and small LED tail lights, drill 2" holes (or as big as possible leaving ~1" above and below the holes - won't hurt strength of the frame at all but will save significant weight) in the sides of frame members, remove stock steering column and replace w/ racing column and light weight steering wheel, get a full set of real magnesium wheels. That should get you way below 2000#.
Rotational / Unsprung weight issues jamnut Suspension - Brakes - Steering 12 01-13-2007 01:17 PM
Weight difference between a SBC V8 and a Chevy V6? Mad Maggot Engine 8 07-07-2005 10:40 PM
Door components weight? baddbob Body - Exterior 6 06-14-2005 09:22 AM
Best Rust Inhibitor? bigbrowndog Body - Exterior 45 11-21-2004 08:26 PM
car still WHEEL HOPS why???? tyson Transmission - Rearend 19 08-11-2003 11:28 AM
