loss of power - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2012, 01:30 PM
loss of power
is it possible to loose power from the trans without knowing it. i built a 383 stroker a year ago, it sounds great runs good, starts right up. but when i take it to the track it only ran a 15.2 so i changed the rear from a 3.08 to 4.11 and only ran a 14.8 . i have been all over this engine, talked to every tech and expert i could, nothing appears wrong with the engine yet every one agrees it should be running in the 12's at the track. sherlock homes once said if you eleminate all the possible , only the impossible remains. the car is a 1978 corvette and its the original 350 trans . any and all comments welcomed, thanks al
Old 05-24-2012, 09:44 PM
Does it have a stall built for drag racing. At the strip , time is all made in the launch. Motor carries you through.
If it is a drag raced car, 3000 minium stall to get those times.
power loss dman0712 Transmission - Rearend 1 05-02-2010 10:28 PM
Power loss bp67chevelle Engine 2 03-17-2010 04:44 PM
Power loss Jake_Dragon General Rodding Tech 5 05-16-2009 09:47 AM
loss of power 123timmy Engine 3 06-03-2007 12:20 PM
power loss skirk Engine 2 03-22-2006 04:15 PM
