Lost - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2004, 03:35 PM
Lost
I've got a 76 chevy nova and I have the chance to get a 12 bolt pos. I got told it was out of a 65 impala. What I want to Know is will it work with out a lot of mods. Thanks
Old 02-26-2004, 04:13 PM
Sandflea427SS's Avatar
Anything with a throttle
Well, I'd have to think the widths would be way off...
But, your bigger problem is the Nova is leaf spring and the Impala is coil spring. Just making some sort of perch for the spring requires welding!
Would something from a late 70s Camaro fit?
Old 02-26-2004, 04:23 PM
yes & no iI've been told some say that camaros and novas the same width .
But then some say that the camaro is wider. Plus this ones free. lol. Then is there any way to change the gears and locker? Sorry lost when it comes to rear ends.
Old 02-26-2004, 11:37 PM
A good rear end shop could modify it, but it would cost a small fortune. What rear end is in your car now? '68-'79 Nova (& clone) rear ends are the same width, as are '67-'67 Camaro & Firebird units (later than '69 are too wide). The '73-'79's all had multi-leaf springs, but most older ones were single-leaf, which used a different height spring perch. 8.5" rears usually need a slightly shorter driveshaft than the others. Here's how to tell if yours is 8.5" (strong), or 7.5" (not so strong):
http://malibunorth.freeservers.com/RearID.html
Old 02-27-2004, 03:54 AM
If the 12 bolt is a 65 Impala unit, it is 4 inches wider (flange to flange) than your Nova rear.
The 8.5-inch 10 bolt in your Nova is nearly as strong as a 12 bolt. If the 65 Impala 12 bolt is yours for the taking, I would get it and sell it, and use the proceeds to buy a good posi and gears for your 10 bolt. With the prices that 12 bolts bring, I would think you could get $500 to $1000 for it, and that is more than enough to build the 10 bolt in your car.
Eric
Okay, I just checked and 1976 was the first year that could have had a 7.5 inch 10 bolt OR an 8.5 inch 10 bolt. Only cars with a 350 got the bigger rear (??).
If your rear has squared-off lugs at the base of the housing under the cover, it's an 8.5. If it has pointy lugs, it's a 7.5. Here's pictures and info.
http://www.geocities.com/forgottennovas/axle.htm
I still say get the 12 bolt and sell it. If you have a 7.5-inch 10 bolt, use the cash to get an 8.5.
Eric
Old 02-29-2004, 01:06 AM
I think the 305 was the only Nova V8 that used the 7.5", & only for that one year. My '78 w/305 came with the 8.5".
Old 03-01-2004, 02:26 PM
Thom Laybourne's Avatar
Easy
Some times the easiest solutions are the hardest to see. You can take most cars to the junk yard and ask them to make the mods for you. Example. For $500 (yes, your is free) I had the yard man change rear gears and add a limited slip (Eaton) to my 55 pickup. I did not have to relocate anything. My time is worth money. Oh, and did I mention that they did all the work. I just dropped it off and went back and drove it home. Two days of wrenching is fun, five days is work.
hr41pearl
