Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - lost 3rd gear on th 350
Old 12-23-2003, 07:22 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Cool
If 3rd gear is gone and reverse is not functioning correctly... the problem is the direct clutch pack.
this pack functions in 3rd and reverse. The pressures are higher in reverse than 3rd, this is why you can loose 3rd and reverse still works a little.
I imagine an over haul is needed on the tranny as mentioned.
