lost - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2006, 07:40 AM
lost
I have a 1977 corvette with some type of brake problems. I continue to loose a stiff pedal, then red light alert stays on. I have bled all brake lines, replace all calibers as well as brake lines. With each new replacement of parts, brakes hold well for a little while then, loss of pedal and dash light stays on. Need help with this one, any suggestions??
Karen
Old 07-26-2006, 08:20 AM
astroracer's Avatar
The only thing left is the master cylinder... Sounds like the next thing on the list to change... I probably would have started here. Unless the calipers are leaking they generally won't cause the light to come on.
Mark
Old 07-26-2006, 08:48 AM
lost
I failed to mention that the master cylinder was replaced twice on top of all the rest. No leaks are noticed.
Karen
Old 07-26-2006, 08:50 AM
1939d2/s10's Avatar
Do a search for gravity brake bleeding,it specifically talks about corvettes,hope this helps, Johnny
Old 07-26-2006, 08:58 AM
lost
Thanks Jimmy will check it out.
Karen
how much hp would be lost? ko.17 Engine 1 04-30-2006 11:09 AM
To anybody who's lost their parents killerformula Off-Topic 11 04-21-2006 06:05 AM
Calculate compression lost using high performance camshaft? newchevyman Engine 25 01-28-2004 08:39 PM
Lost Spindles Thom Laybourne Suspension - Brakes - Steering 0 01-28-2004 04:47 PM
Boy did i get lost! Phat Hotrodders' Lounge 5 01-17-2003 06:30 AM
