-   -   Lost electrical connector (http://www.hotrodders.com/forum/lost-electrical-connector-226351.html)
abbazabba 11-21-2012 06:04 PM
2 Attachment(s)
I have a 98 Chevy k1500 5.7
I can't figure out what this connector goes to.
It comes off the same section as the crank position sensor and a ground strap.
Anyone have an idea?
Thanks!
seltec8 11-21-2012 06:39 PM
air pump ?
abbazabba 11-21-2012 06:49 PM
What the hell is an air pump
seltec8 11-21-2012 07:16 PM
Actually the diverter valve bolted to the air/smog pump? What are the colors?
abbazabba 11-21-2012 07:26 PM
Its a
2 pin
red with light blue boot
I will have to look at it again to get the wire colors.
abbazabba 11-21-2012 09:04 PM
Wire Color
Seem to be Black and Yellow
seltec8 11-21-2012 11:28 PM
I was thinking red & black.
1) Not all trucks came with an air pump if was dirty then it wasn't used.
2) There may be a coolant switch that replaced the block drain plug. (plug is at the pan rail just forward of starter end plate). a yellow or light /green color would make sense
3) It doesn't seem long enough to go to a low coolant switch in the radiator tank.
Online kinda sucks for a schematic. You can take your thank you back if you want.
Good luck
