Lost electrical connector - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2012, 07:04 PM
I have a 98 Chevy k1500 5.7
I can't figure out what this connector goes to.
It comes off the same section as the crank position sensor and a ground strap.
Anyone have an idea?
Thanks!
ID:	69279   Click image for larger version
Old 11-21-2012, 07:39 PM
air pump ?
Old 11-21-2012, 07:49 PM
What the hell is an air pump
Old 11-21-2012, 08:16 PM
Actually the diverter valve bolted to the air/smog pump? What are the colors?
The Following User Says Thank You to seltec8 For This Useful Post:
abbazabba (11-21-2012)
Old 11-21-2012, 08:26 PM
Its a
2 pin
red with light blue boot
I will have to look at it again to get the wire colors.
Old 11-21-2012, 10:04 PM
Wire Color
Seem to be Black and Yellow
Old 11-22-2012, 12:28 AM
I was thinking red & black.
1) Not all trucks came with an air pump if was dirty then it wasn't used.
2) There may be a coolant switch that replaced the block drain plug. (plug is at the pan rail just forward of starter end plate). a yellow or light /green color would make sense
3) It doesn't seem long enough to go to a low coolant switch in the radiator tank.
Online kinda sucks for a schematic. You can take your thank you back if you want.
Good luck
abbazabba (11-23-2012)
Electrical Pin Connector S10 5 speed Mrwood Electrical 1 11-12-2010 07:26 PM
T-350 with a electrical connector? Short_box Transmission - Rearend 10 08-18-2009 09:25 PM
Another strange electrical connector cboy Garage - Tools 5 05-08-2008 08:17 PM
GM electrical connector zipfactor Electrical 8 08-12-2006 10:51 AM
700r4 Electrical connector arch Transmission - Rearend 5 06-22-2004 05:49 PM
