lost my 2nd gear on a 700r4 why? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2007, 08:25 AM
hi i have a 1970 elco with a zzr i just installed a 700r4 while testing my tv placment i somehow lost my 2nd gear now the car wont get 2nd at all is my tv placement that far off what did i do?
Old 02-16-2007, 05:45 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Does the trans shift to 3rd gear? Do you have over drive (4th) ?
OR no up shift at all?
TV cable minimum NOT set correctly could cause the trans to enter the 'fail safe' mode and shift very late.
Could be a governor plastic gear broken.
Could be a broken band strut hole.
Old 02-16-2007, 05:48 PM
2nd gear
yes i can manualy shift it into 3rd i dident try to go into 4th was worried i might make it worse i have the b&m megashifter with the electric lock up i can adjust
rear gear ratio with 700R4? 68firechicken Transmission - Rearend 4 08-06-2006 12:58 PM
700R4 will not shift into 3rd and 4th gear bebopwally Transmission - Rearend 14 05-25-2006 07:48 PM
700r4 tranny in 2nd gen 1980 camaro !HELP! william27103 Transmission - Rearend 10 11-02-2005 06:53 AM
700r4 shift problem,1st to 2nd root Transmission - Rearend 2 10-19-2003 11:31 AM
AOD Ford tranny (lost fourth gear) shagginwagonvic Transmission - Rearend 8 10-13-2002 01:48 PM
