Lost oil pressure, now knocking sound. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2011, 10:17 PM
BigRoy1978's Avatar
Ok, long story short.
driving back from school in my 72 e-200, 302 ford power, when the oil light comes on. It ran for a few moments before I shut it off, and pulled over. Pulled the dipstick, not a drop of oil. I checked the oil about 75 miles before, and it was full. The ENTIRE bottom of the van is covered. Anyway, I filled it back up, started it. No oil light, but there is a knocking sound now.
Could it be a rod knock? if so, that means a set of bearings, correct? Any other thoughts on what it could be? any help is appreciated.
Old 01-28-2011, 10:43 PM
Knock
Well if it a rod bearing you will have to do a tear down. Find out which rod bearing spun. The rod end will also have to be resized. Also have the crankshaft checked. If ok install new bearings. Are you sure it's a rod or could it be a lifter? That would be a lot easier. If you have a lot of miles on the engine it would be a good time complete rebuild. Good luck.
Old 01-29-2011, 04:13 AM
sqzbox's Avatar
My pipes are my music
From what you describe, a rod bearing has spun. You'd be darn lucky to just get by with a new set without having to do a bottom end rebuild. Might be cheaper to just find another used engine you can drop in over a week end if it's your daily driver. I hate to be the bearer of bad news, but I've spun a few myself and haven't got lucky yet.
Old 01-29-2011, 07:15 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 you would be very lucky to spin a bearing and not have to do a bottom end job. JMO
Cole
Old 01-29-2011, 09:37 AM
BigRoy1978's Avatar
Its not my daily driver, being as I have another vehicle. I think I'm gonna look for a roller cam block (80's) in either 302 or 351.
About what does a roller cam 5.0 liter go for these days? Im talking like what the fox body mustangs/crown vics had in them.
Old 01-29-2011, 11:10 AM
68NovaSS's Avatar
Wiki Edits: 9
Even though it's a moot point, where did all the oil on the underside come from?
Old 01-29-2011, 11:48 AM
I was wondering the same thing, were did the oil go?
I wouldnt just replace the bearings either since that most likely doesnt do the trick. I had a similar issue and I just got me a good used 360 for $300
(Mopar Truck) and dropped it in. Worked well for me.
Tomi
Old 01-30-2011, 12:51 AM
BigRoy1978's Avatar
Im not sure where the oil came out of, but its everywhere.
Im looking into finding a short block before too long. I think a 351 would slip right in where the 302 did, but im not sure.
350 making a BAD knocking sound! BigRoy1978 Hotrodding Basics 12 12-31-2010 10:31 PM
LOUD knocking sound glennsea Engine 19 09-17-2010 05:47 PM
knocking sound 81scottsdale400 Engine 3 03-11-2010 05:57 AM
Knocking sound from the rear Arcuden Transmission - Rearend 1 08-14-2005 03:05 AM
A knocking sound, HELP! 87442lover Engine 2 07-18-2004 07:03 PM
