Replace the module w/a known good one if you have one around. The other thing in the distributor that can cause a no start condition is if the pick up coil has gone bad or has a broken lead going to the module. This isn't as common as a bad module, though.
You don't have to remove the distributor to test it, you do need to disconnect the module from it before checking the resistance. If it's bad the distributor will need to be removed.
When you replaced the coil, was the part below in place and in good shape?
The carbon brush on the left goes in the cap first, then the rubber gasket. Should have dielectric grease both sides of washer, then the coil goes over them both.
If you have spark at the coil but not at the plugs either the rotor or coil wire are no good or installed wrong or the coil wire is no good. Is this a small cap HEI setup or something aftermarket.
Wrong rotor, is a possibility. If you still have the old one compare it. If there is spark at the coil it travels through the coil wire to the rotor and back out the end of the rotor to the plug wires. Not a lot that could go wrong that would affect all cylinders.
Sounds like something killing the module. The coil could be doing that. Even if you are using a new coil,things arent what they used to be.
Another thought would be the alternator may be passing alternating current killing stuff.Have you had any charging system problems lately?
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
