lost speedometer cable - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2005, 05:28 PM
me and my dad took a 350and a 700 r4 out of a chevy 1/4 ton and put it in a 88 chevy 3500 replacing a454 and turbo 400 trans, ever thing is working fine except we cant find the speeometer cable to hook to the trasn tried following it out of fire wall but still no use, was it elect wired to a cable/ just seam lost/
Old 08-01-2005, 02:41 PM
I'm not sure when they switched to electric speedo. Have a look at the 400 trans you pulled out. At the rear, drivers side of the trans you will find either the screw attachment for the cable or a sender with an electrical plug on it. That will tell you if you have a cable. Otherwise look at the back of your speedo, if you lost the cable there will be a spot for the cable to click into. Happy hunting. You can convert your cable drive trans to electric speedo by removing the rear tailshaft cover and swapping the gear for a sender unit, or with an aftermarket adapter.
speedometer with its own mind???? Old School Nut General Rodding Tech 15 06-06-2008 04:10 PM
E-Brake Cable MI2600 Suspension - Brakes - Steering 10 06-01-2005 10:15 PM
Speedometer Information. M&M CUSTOM Transmission - Rearend 0 04-03-2005 08:47 AM
Speedometer cable noise stinky jinx Transmission - Rearend 3 03-24-2005 11:23 AM
Throttle Cable problem Jag Daddy Engine 2 05-30-2004 09:07 PM
