This is a lot of sludge... - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-08-2010, 06:59 PM
Originally Posted by K and K
Pulled the valley plate on a 57 Caddy 365, I knew I'd find sludge but not this much...
Ahh, yep! Really common engines tended to run too cold back then like 140-160 degree thermostats were the thing. Oils were not as refined as they are today having a lot of stuff that mixed with crankcase water vapor, and the lead and bromine in the fuels to make this stuff, then not changed often enough. Even the detergent oils of the 1950's, 60's and 70s weren't good enough to prevent sludge formation. Many people wouldn't run detergent oils, as has been said the introduction of detergent oils to already sludged up engines loosened enough of that stuff to were it circulated either plugging the the intake to the pump or if missed by the filter some small but important feed hole, rockers probably got the worst of it nearly everybody and especially the Ford Y block had top end oiling problems. So detergents got a bad rap from doing what they were intended to do to sludged old engines. Starting with a new engine and detergent oil wasn't a problem but if the engine had many miles and only non-detergent oil in one was better off to stay with the non-detergent oils. With road draft tubes for ventilation, engines that saw a lot of in city driving had bigger problems than highway driven vehicles since they didn't get warm enough to drive the water vapor out nor driven fast enough to suck the vapors into the passing air stream so they filled up on blow-by venting only excess pressure from the tubes rather than drawing clean air in one end and venting the gunk from the other.
Yours is really a case where the engine needs to be cleaned by removal from the car and partially disassembled to clean it. Loosening this stuff in place risks getting chunks into circulation with the oil. If the engine holds good compression I wouldn't pull the crank, rods or pistons out. But I would pressure wash and well flush the crankcase with a solvent. Usually the upper parts of the crankcase are pretty clean where there is a lot of oil wash from operation. The ugly places are what you already see in the rocker boxes and valley. The other really icky places will be the timing case and the pan.
Once clean reseal it and put it together and drop it in the engine room.
Everybody, well us older guys at least, have stories about this stuff gone wild. My personal favorite was a guy that came in the shop complaining that after he drove for 15-20 minutes his Chevy V8 lost all oil pressure and when he allowed the engine about an hour of rest, when restarted the oil pressure was back, then the cycle repeated. He went on to say that when the oil was checked at pressure loss the pan would be empty and after that hour it would be full again. Pulling the rocker covers, I should say once I fought them off, and pulled the intake; one could see that the sludge had nearly closed the oil returns. The rocker covers and valley filled with oil finally lowering the level in the crankcase to where the pump had nothing to pump. When shut down for an hour the oil would finally drain back and everything would appear normal in the pan. I treated this as I describe above using Safety-Kleen which is less of a fire hazard than most other solvents and we had plenty of it at the shop. The heads, rocker covers, inside of the intake, the timing case and pan were cleaned by first scraping and scooping, then solvent washed. Wiped it out and dried it with lint free towels, replaced the timing set, seals and gaskets, lubed the cylinder walls and bottom end with a spray of Marvel Mystery oil (just love the fresh mint smell) put in the car, filled with oil and fresh filter and fired it up.
The owner had never changed oil only topped it up when needed which is how he got into this problem on the extreme edge of the sludge issue.
Bogie
  #17 (permalink)
Old 12-13-2010, 12:45 AM
K and K's Avatar
Last journal entry: Original 365
Good and bad when I pulled the pan. Good it that there doesn't appear to be anything close to rubberized sludge that was in the top end. Bad is that the pump pickup feels real loose in the pump. On these engine a cotter pin holds the pickup to the pump body, but it appears to be metal tube sliding into a metal housing. Not sure how much a rebuild kit will help the pump.
This could let in air any time oil level is below where the pickup tube slides into the pump, I also found a pinhole on the pickup on the reverse side of the pickup screen. This cold let any air in as well.
There is sludge built up behind the screen around the inlet tube.
ID:	50764   Click image for larger version
  #18 (permalink)
Old 12-13-2010, 12:48 AM
K and K's Avatar
This tube isnt a tight press fit like you might find on a sbc where you only tack it for insurance, it rotates really easy in there and is only secured by a cotter pin, so if I only tack it, I think there is a chance for air to get through still. What do you think?
Here is the oil pump pickup with the odd hole on the reverse side of the screen. It looks like a an old spot weld for some reason. You can see it pukes oil when you squeeze the canister that is the pickup housing. You can see behind the pickup screen, the inlet tube, but also that it is like a canister behind the screen. I just want to make sure that this hole doesent serve a purpose before I weld it up. Also any that read my post earlier about the pickup sitting loose in the pump housing can see the only sealing element is the flat rubber gasket that has since turned to brittle rock.
If anyone would give any input on this pickup I'd be grateful.
ID:	50766   Click image for larger version
ID:	50767   Click image for larger version
ID:	50768   Click image for larger version
ID:	50769   Click image for larger version
  #19 (permalink)
Old 12-13-2010, 12:50 AM
K and K's Avatar
Here are some more pics showing the only sealing element that seals the pickup to the pump housing, and oil coming from the odd hole I cant identify. Any input would be greatly appreciated.
ID:	50771   Click image for larger version
ID:	50772   Click image for larger version
  #20 (permalink)
Old 12-13-2010, 06:59 AM
Wiki Edits: 27
de sludge time.
chevy I 6 and ford 292's would plug up the oil feed passage to the rocker arms They would really get noisey as the metal wore out. A lot of Fords had the outside oil line kit to the rockers, On chevies you pulled the rocker arm-stands an ran a wire thru the hole then solvent and then blew with the air hose, usually every couple of months. when I was in school and broke. I would buy a gasket kit, disassemble everything, clean it up, scuff the cylinder walls with 400 paper, clean the valves and lap them in. Then an engine was good for a couple of years of everyday driving. For an oil change sometimes we would pull the spark plugs and mix some kerosene and a quart of fresh oil , crank for a couple minutes to flush an engine before refilling with oil.
chevy I
  #21 (permalink)
Old 12-13-2010, 08:04 AM
sludg
had a 55 ford yblock,worked in a logging camp,i used series 1 oil(for diesel engines) changed it every 3000 miles,at 90000 pulled valve covers for valve adjust,the engine was spotless.so my tho-ts are and still is good detergent oil and regular changes.And do not use current oil for diesels in engines with flat tappet cams. this engine had the road draft tube,so i do not agree that pcv valve is the cure for sludge. the lead in fuels was a contributor as well as lack of servic with quality oil and filter. cliff
  #22 (permalink)
Old 12-13-2010, 01:47 PM
K and K's Avatar
What do you guys think about conditions of the oil pump pickup? I searched for pics of this pump and through blurry images it looks like other pickups have the same looking spot weld on the rear. I just want to make sure its not supposed to be a pin hole before I plug it.
Fluid change on a turbo 350 after a rebuild with fibers and sludge in pan? supercab78 Transmission - Rearend 4 02-23-2009 08:45 AM
epoxy primer sludge 124boy Body - Exterior 10 07-09-2008 07:41 PM
Engine Sludge Rightytighty Engine 5 03-28-2007 10:33 AM
Would these heads add a lot of power? Rubberman2003 Engine 6 08-10-2003 08:20 PM
Motor oil causing sludge. Is one brand better than another?? Jim Weeks Engine 7 04-30-2002 06:39 PM
