This is a lot of sludge... - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-07-2010, 07:38 PM
K and K's Avatar
Last journal entry: Original 365
Pulled the valley plate on a 57 Caddy 365, I knew I'd find sludge but not this much...
ID:	50669   Click image for larger version
Old 12-07-2010, 07:53 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
yikes!
artsvettes's Avatar
That was typical back in the day. Pretty much went away when closed crankcase ventilation came into play. Along with better oils
Old 12-07-2010, 07:57 PM
K and K,
I have seen this many times in the OLD cars.
They run colder than cars now is the first thing. Not changing the oil enough. We were taught to change our oil every 2 to 3 thousand miles but some people did not put on that many miles so they did not change the oil. Also
oils BACK then was non-detergent. So sludge would build up faster.
You are in for some DIRTY work here.
Good Luck in the clean-up
Scholman
Retired
K and K's Avatar
Closed crankcase ventilation, such as pcv valves where cc pressure isn't routed straight to atmosphere? How would this affect sludge build up? I was under the impression this was always due to running bad and old oil? What really affects it?
Old 12-07-2010, 07:59 PM
K and K's Avatar
Originally Posted by scholman
K and K,
Scholman
Retired
When I started the motor before I picked up the car I heard squeeks in the valvetrain under the driver side v/c. Found lots of sludge on top of the heads with no oil getting up two of the push rods to two of the rockers, so I suspected it'd be nasty under the valley plate. Cleaned the heads good with seafoam and reamed out the p/r's with safety wire.
Oil flowed up all rods good then.
After I put the covers back on with new gaskets I found it seeping at the rear of the v/c's. Pulled the covers again to find that ALL oil getting pumped up to the rockers was staying up there because the oil drain back ports were plugged! Reamed that all out as well. Drains back now.
Old 12-07-2010, 08:33 PM
T-bucket23's Avatar
Wiki Edits: 26
A lot of the old oils had parrifin in them. basically it is wax. It would build up like crazy if not changed regularly. It was not unusual to pull apart old engines and see stuff exactly like that. I remember pulling the valve covers off a late 60's mopar and they were literally full except where the rockers were moving in the sludge.
Chet
Old 12-07-2010, 11:11 PM
001mustang's Avatar
64 5 bolt 289 no PCV
My 64 289 w/ road draft ventilation was rebuilt over 10 years ago.
The oil gets black quick but I haven't noticed sludge build up.
May rig up a temporary PCV one day.
ID:	50676   Click image for larger version
Old 12-07-2010, 11:48 PM
SSedan64's Avatar
Chet, I bought an old 60 Chevy Van w/I6 years ago. It was the same, V-covers filled to the top except where the rockers moved. My Dad said the same thing, (Good ole paraffin oil). I was about 16 at the time. I started to clean the crud out & He stopped me & said unless you're gonna drop the pan you better leave it alone. It had Quaker State oil cans everywhere inside.
Todd
Old 12-08-2010, 03:21 AM
sqzbox's Avatar
My pipes are my music
I'll bet Superman could squeeze that into diamonds!
Old 12-08-2010, 06:42 AM
T-bucket23's Avatar
Wiki Edits: 26
Todd
A lot of people lost engines when the high detergent oils first came out. It would start to loosen up all that crap, plug the oil pickup and boom. I was in trade school in the early 70's and we did a lot of Ford engines with completely plugged screens. Usually not to long after an oil change with high detergent oil.
Chet
Old 12-08-2010, 10:04 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Todd
Yup go old Quaker State I see the commercials today and slug pops into the minds eye.... and the cure the kerosine flush?
Old 12-08-2010, 10:27 AM
ogre's Avatar
the 'Duracell Project'
did that motor have a filter on it or was that a pre-filter engine?
that motor might benifit from 2 qts oil and 3 qts of kerosene run through it
warm it up, drive it (no hills) and drain it while it's hot
i've done this on older motors bought from the jy
Old 12-08-2010, 10:35 AM
JeffB's Avatar
I remember building Y-blocks for dirt track in the late 60's and finding worse than that from Shell oil,one was so bad the sludge was all the way to the bottom of the valley cover and filled up a water bucket after we scraped it out.
Old 12-08-2010, 05:52 PM
LATECH's Avatar
several years back i pulled the valve covers off of a 302 79 t bird and you could see the ford emblem imprinted in the sludge. You could barely see the rocker arms. I put the covers on and administered last rights.
Fluid change on a turbo 350 after a rebuild with fibers and sludge in pan? supercab78 Transmission - Rearend 4 02-23-2009 08:45 AM
epoxy primer sludge 124boy Body - Exterior 10 07-09-2008 07:41 PM
Engine Sludge Rightytighty Engine 5 03-28-2007 10:33 AM
Would these heads add a lot of power? Rubberman2003 Engine 6 08-10-2003 08:20 PM
Motor oil causing sludge. Is one brand better than another?? Jim Weeks Engine 7 04-30-2002 06:39 PM
