lots of aluminum corrosion in stock HEI distributor - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2009, 03:46 PM
fast68's Avatar
likes chevy trucks & boobies
well i have been messing around with the 305 in the 82 trans am i have been keeping parked around here since 2000 and messing with
been having real issues with it starting up and running correctly
when i first put the engine in around 2005 or so it was running great
but over time it got worse i noticed
i kept assuming it was the carb so i would swap another one on it
but then eventually it would run bad again, sooner than later
i was messing around with it again today so i could move it to another spot and i noticed that the idle was staying and sticking for no reason at around 2000 rpm or so even when backing off the carb curb and fast choke idle screws and checking the choke linkage
no vacuum leaks
couldnt figure it out until i went to move the distrib by pushing on the vac advance canister and as soon as i touched the canister the idle dropped out and it stumbled and died
so i then deduced that the problem must be with the distributor, evne though i didnt want to believe such, because its a rare thing to be the cause of bad running engines, usually.,
so i set it to #1 tower real quick, and yanked it out
and wow i immediatley noticed that it was like "full" of aluminum powder corrosion junk really bad
i have had tons of stock hei dizzies over the years and never seen this before.
what could cause this ?
like super fine gunpowder or something like gray in color
is this really corrosion, or is it something else?
i read another hei problme thread just now and it was talking about water getting on it and maybe getitng in the cap somehow(i dont understand how its possible)
but thi sis very likely because my trans am has the factory power bulge hood that is open above the back center of the engine
wide open to the engine
and it has been yet another record rainfall year here and this car is always uncovered out in the open.
gonna put a remanufactured distributor i have laying around, from another engine, in it here in a bit and then see how it runs,
Old 08-31-2009, 04:42 PM
no vacuum leaks
Sounds like moisture gets into it, given where you live has a lot cool to cold and damp weather and salt on the roads, this doesn't surprise me a lot. But some distributors seem to suffer more than others.
I'd look for water getting down the hood scoop and/or around the firewall to hood seal. Check to see the rubber flaps that close off the inner fender over the back of the A-frames are still in place. Check the radiator overflow tank for leakage that is spilling coolant into the engine compartment, stuff like that.
But frankly, you're seeing mostly why unless I lived in the desert southwest, I wouldn't have a hood scoop. There just isn't anyway to keep those things from leaking onto the top of the engine.
Bogie
HEI Distributor Gear Shims JohnTN Engine 4 12-17-2005 06:46 AM
Condensation in HEI Distributor ixlr8a67 Electrical 10 09-23-2005 09:30 AM
HEI Distributor Ratteling Houman SS '70 Engine 1 07-10-2005 12:24 PM
HEI Distributor Problem Jag Daddy Engine 3 11-06-2003 11:48 PM
Changing to a HEI distributor BadBowTie Engine 6 08-27-2002 07:52 AM
