Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Lotsa smoke at startup. (Stock Chevy 350 with Q-Jet carb)
Old 07-16-2004, 07:11 PM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Wiki Edits: 9
Valve seals and rings, the 23 year old 267 in my Malibu has the exact same thing, blue smoke at start-up.
For comparison purposes.
If you have black smoke it is from too much fuel.
White steamy exhaust at start-up is normal, BUT after the engine is warmed to operating temperature you would be experiencing a coolant leak into a cylinder from most likely a head gasket failure.
