-   -   LOUD POP! noise when turning right in S-10 (http://www.hotrodders.com/forum/loud-pop-noise-when-turning-right-s-10-a-55878.html)
cknox88 01-11-2005 06:51 PM
ok heres the deali have a 91 s-10 4wd. ok so the other day my brake caliper froze up about a half mile from home. i stopped hit the caliper a couple times with a hammer and the piston went back in a little. os i drove it home tore it down got the parts fixed it and now when turning right if i hit a bump while in the turn it pops real loud. its acually missing a stud on that wheel that im going to replace tomarrow but that cant be whats causing it because its been like that for about 3 weeks. so if anyone knows what this possibly is plaese reply.
Thank You
68NovaSS 01-12-2005 09:42 AM
Did you replace or at least ensure the old "O" rings were in place where the self adjuster sleeve passes through the caliper body?
Stinkin_V8 01-12-2005 09:47 AM
Maybe a torsion bar mount? They're a chronic problem on the 4WD S-10 but usually make more of a clunk than a pop.
The only other thing I can think of is maybe a sway bar mount up front..
Where is the sound coming from? Up front, or under your feet?
cknox88 01-12-2005 07:31 PM
im not sure what your talking about that self adjuster sleeve explain that to me better if you would. The sound is coming from the drivers side front wheel area.
