Loud tapping noise under driver side valve cover - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2012, 07:53 PM
Someone told me that it was a loose rocker arm. They told me how to fix it but due to bad memory can't remember how. So I wonder does anyone know how to fix this? I know they told me that I can't just tighten down the nut that I'd have to take off the rocker arm and manually turn over the motor and figure out when the valve was fully open and then put the rocker arm back on. How would I know when it was fully open?
Old 12-09-2012, 08:22 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
First thing you need to do is put down Make model year and engine size! There are many configurations of valve trains we need info to answer your question
Jester
Old 12-10-2012, 06:38 AM
Hahaha yea I guess that would help...350 SBC
Old 12-10-2012, 07:19 AM
delawarebill's Avatar
TDC of that cyl is needed
that way both valves are CLOSED... loosen the rocker, the start twisting the push rod while tighting down the rocker nut.. when it starts to not be able to turn then tighten another 1/2 to 3/4 turn... done !!
Old 12-10-2012, 10:08 AM
Jester
ok well there this tapping noise while idling chevy302builder18 Engine 3 07-15-2011 11:22 AM
Tapping noise in engine? Bucketwrench Engine 10 11-29-2009 09:37 AM
Tapping noise. Johnx64 Engine 8 06-19-2008 08:56 PM
loud ticking noise from right side exaust only mempis1 Engine 10 08-31-2007 06:37 AM
Higher RPM Tapping Noise 400smb_s10 Engine 5 08-07-2007 02:42 PM
