louvered hood - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2008, 09:21 PM
louvered hood
anyone have a louvered hood for a 1947-1953 chev pu?
Old 04-02-2008, 09:44 AM
Wiki Edits: 27
it's easy
the hood is wide open under neath. very few braces. the curve of the hood means the press will have to be large enough.. you need to remove all the paint and have the metal clean top and bottom then depending on the press size plan where to put them and the pattern to use.
Old 04-02-2008, 10:14 AM
lets cut it up's Avatar
I don't have one already done but If your not welding the hood halves together for a seem-less look you could take out the spot welds and separate the two halves of the hood
to easier access the stamping machine then when done just put the hood back together . Thats if you can find somebody to stamp it for you.Tim
Old 04-02-2008, 05:43 PM
I was looking for someone that may want to sell a louvered hood.
Old 04-02-2008, 06:09 PM
Are there dies available to do louvers by hand ? I checked with "Greenlee" and they don't have a handheld. Maybe someone here knows.
Thanks
Old 04-03-2008, 10:56 AM
Wiki Edits: 27
cut them by hand
the metalmeet site shows some hand made dies.... the racers in the 20's used to hand cut their own I used to have a book that showed how to build your own race car body,,,printed in the 20's... lost it in a house fire... the old way was to lay out the louvers, drill a small hole at each end then cut the slot with a sharp wood chizzel... use hand made dies out of hard wood..with small nails with the heads cut off to align the dies then hammer the form. I saw some done a couple of years ago that were done with out the nail holes...the hand wood form did not make the sharp corners that a metal die in a press can do but they were different and looked ok..
Old 04-03-2008, 02:08 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Place a free ad in the classifieds on this site.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 04-04-2008, 02:21 AM
the metalmeet site shows some hand made dies...the hand wood form did not make the sharp corners that a metal die in a press can do but they were different and
looked ok..
thanks timothale, for taking the time
Enjoy
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 08:10 PM
Best ways to straighten a twisted repro door? Ripped Body - Exterior 13 07-04-2005 08:29 AM
body parts fitting anyoldchevy Body - Exterior 10 02-20-2005 10:20 AM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 05:42 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 07:50 PM
