low beams wont turn on , but if i turn high beams on - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2011, 12:05 PM
ok so my 1966 caprice headlights would not turn on so i hit the foot switch for the high beams and both sets o light turned on, so bulbs are good. does anyone know what might be going on!!!thanks
Old 06-14-2011, 01:07 PM
ogre's Avatar
the 'Duracell Project'
the easiest thing to do is get a multimeter and chase the problem.
first check at the bulb and work your way back.
only 1 wire to chase...
if you have quad headlights, i suspect a ground problem
Old 06-14-2011, 02:36 PM
First of all, the fact that the low beams are on with the high beams does NOT mean the bulbs are good. The low beams have two separate filaments, one that lights on low beam and one that lights on high beam. That's why the low beams have three terminals but the high beams have only two.
It's entirely possible that both low beam filaments have burned out. If the bulbs really are good, then the dimmer switch is the most likely problem.
Old 06-14-2011, 04:21 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Needs a new (DIMMER SWITCH) should fix it.
Cole
Old 06-14-2011, 04:29 PM
Irelands child's Avatar
Yes, both lows can burn out at the same time as it recently happened to me with a pair of halogens, but seldom with the old sealed beam bulbs. The plug on the switch just may be loose/partially disconnected or that $10 buck switch went dead.
Irelands child
Old 06-15-2011, 05:24 PM
Probably the foot switch, since both are on when you select the high beams, it tells you the wiring between the head lights and the switch is functional as they should both be on when high beams are switched to on. So there's power into the switch and power out on the high beam side what's in the middle is the switch so my best guess would be part of the switch has gone dysfunctional.
Bogie
Old 06-15-2011, 06:44 PM
pin connector
I had the same problem with my 57 gmc. Changed dimmer switch, that didn't help. Traced wires and come upon a pin connector that was loose. Fixed that, feed the cows and called it a good day. Don't know if this will help in your application. Just another possibility.
Old 06-15-2011, 08:38 PM
hp246's Avatar
Yep Dimmer Switch. I also have had the same problem.
Old 06-16-2011, 08:21 AM
Bogie
Sorry, but this is not true for GMs. The low beam bulbs have two filaments and two separate wires from the dimmer switch. The fact that the high beam filaments light does not prove that the wiring to the low beam filaments is functional. As I noted previously, the problem COULD be the dimmer switch, it COULD be the wiring, or it COULD be the low beam filaments are burned out. It's easiest to check for voltage at the low beam terminals of the headlight sockets, since that costs nothing, before buying any replacement parts.
Old 06-16-2011, 08:31 AM
Will I ever get it done?
Last journal entry: Hood
Come on Joe, it is far easier to start changing parts than to diagnose the problem, fix the problem right, and save money.
Old 06-16-2011, 10:21 AM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Hee Hee, nothin like a little healthy sarcasm .
Old 06-23-2011, 03:51 PM
I had the same issue with my 72 C20. All I did was pull the plugs from the back of the lights, clean the posts and snap them back on and low and behold it fixed the problem.
In my experience the simplest solution is normally the correct one.
High beams bright, low beams very dim Aerotech Electrical 29 08-06-2010 08:29 PM
Headlight wiring - low & high beams cboy Electrical 11 02-27-2010 07:35 AM
High Beams go out!!!!! gman536 Electrical 10 02-08-2010 05:24 PM
No High Beams -74 Vega GT Hoonbash Electrical 4 04-24-2008 02:16 PM
6" High/Low sealed beams butch27 Electrical 3 11-14-2006 03:49 PM
