Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Low Brake Pedal
Thread: Low Brake Pedal
Old 12-07-2003, 07:15 PM
S10Fan's Avatar
S10Fan S10Fan is offline
Garage Filler
Last journal entry: I need more time!
I have a 1987 S-10 with the same brake setup as yours. The S-10 MC wouldnít work for me. Iím currently working with a MC from a 94 Blazer (1 1/8 bore). My pedal came up some but not enough. The truck stops really well but I canít handle the low pedal. So far Iíve used 2 quarts of Dot 3 bleeding the brakes with no difference. I plan to bypass the prop valve next weekend and see what happens. The Blazer MC is a reman, I guess it could be a bad one. The Pontiac Fiero crowd uses the Blazer MC works really well for those cars (4 wheel disk).
