Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Low Compression
Thread: Low Compression
Old 06-23-2009, 07:34 PM
techinspector1's Avatar
techinspector1 techinspector1 is online now
Wiki Edits: 326
"very low compression across all cylinders"
There are two components that have to seal up to make a motor valid, valves and piston rings. Neither is a "fairly easy fix".
The cheapest fix may be to transplant another motor from the boneyard. Find a good compression, low mileage motor and swap it out yourself. I'd consider a swap in either case, whether you plan to keep it or to sell it.
