Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Low Compression
Thread: Low Compression
Old 06-23-2009, 08:39 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
What PSI to you is considered "Low compression"??
Have you looked it up? I wouldn`t think the compression ratio of this engine to be particularly great. Give each cylinder a shot of marvel mystery oil and let sit over night. Then redo your compression check with the throttle set at wide open and all the plugs out.
