Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Low Compression
Thread: Low Compression
Old 06-24-2009, 08:56 AM
454C10 454C10 is offline
gages can be wrong. try with another gage.
the chances that all 4 cylinder have the same "low compression" from bad valves and rings is very low. Typically 1 or 2 will be low, but not all 4.
a timing chain with retarded timing will reduce cranking pressure on all cylinders.
