Low compression - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2009, 08:32 AM
Low compression
I have a 1981 oldsmobile cutlass with a 350 vortec in it, this has been a project and has been sitting for sometime now so im ready to put it on the road but now i find out it has low compression on the left side. what can i do to build up the compression?
Old 07-01-2009, 11:36 AM
DoubleVision's Avatar
Find out why it`s low on that side would be my first step. While it could be several things, it could also indicate a rebuild is in order.
Old 07-01-2009, 04:14 PM
do the heads have the same casting numbers?
Does a tunnel ram raise or lower Compression?? d&c repairs it all Hotrodding Basics 61 02-02-2009 06:00 PM
Dynamic Compression Ratio?? starnest Engine 3 04-27-2007 02:22 PM
Compression question for the Pro engine builders.. Axelrod Engine 14 01-16-2007 10:29 AM
Compression concerns. Siggy_Freud Engine 4 07-11-2006 10:06 AM
will compression be too low???? joe28boxer Engine 6 10-08-2003 07:30 AM
