Low cost gauge dress up - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2012, 01:12 PM
Mutt's37Buick's Avatar
Aftermarket gauges run over $500 to work with my 4L60E transimission.
I'm looking for a way to dress up OEM gages (that I already have) so they look like an aftermarket gage set set in a nice bezel panel.
If I take the plastic front cover off the instrument cluster then I'm left with gages on a black panel.
If I could buy faces, glass, and bezels, these could be mounted to a panel that hides the rest of the instrument cluster.
1) Does anyone know where I could buy silver faces, front glass, and trim bezels for one 3 3/8 speedometer, and two partial sweep 2 1/16 gauges. (Any brand name)
2) Alternatively, is there a place were I could buy electrically or mechanically broken gauges for parts? (Any brand name)
I plan on mounting a tach on the steering column.
Thanks
Name:	IMG_0086 compressed.jpg
ID:	67142   Click image for larger version
Name:	Autometer 33989G.jpg
ID:	67143   Click image for larger version
Name:	Speedometer, silver face, Autometer.jpg
Old 08-01-2012, 06:15 PM
hp246's Avatar
I've never tried to brighten up the gauge face itself, but have used some vinyls to spruce up a dash. There is even a mylar/vinyl l that replicates engine turned material. I've used these guys a couple times in the past: Metro Engine Turn Vinyl
I received a bad piece of material once and a phone call resulted in a new piece being posted the next day.
Low cost traction improvement hp246 Suspension - Brakes - Steering 5 04-23-2011 09:52 AM
low cost crankshaft? backyard71nova Engine 3 10-25-2007 07:25 AM
Be aware of Low Cost, Low Quality Aluminum Heads Larry3 Engine 17 04-21-2006 07:05 AM
Low cost Gasser cpprint1 Introduce Yourself 1 12-27-2004 01:56 PM
low cost sheet metal jackfrost51 Body - Exterior 3 05-09-2004 05:01 PM
