Low cost homemade welding tool. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2007, 08:56 AM
We have all seen this tip mentioned on the forums, I thought I would put it in the "flesh." Weld won't stick to copper or brass. So, if you had a hole in metal you could temporarily put a piece of copper or brass behind the hole, weld into the edge of the hole with your MIG and literally fill the hole up without the weld falling thru. Remove the copper or brass and the back side will actually be as smooth as the surface of the copper or brass! It is a very neat trick and there are a bunch of tools you can buy for this purpose.
For example, I have a pair of "Vice grip" pliers with the copper backing built onto it. This is a very useful tool and like all tools, you just can't have enough. But it is very limited by the "throat" of the tool. If you have a hole out in the middle of a panel, it is worthless.
One day I found myself needing a copper backing, I walked over to a pile of pipe cut off a piece about 9" long, smashed one end down real good with a hammer and a new tool was born. This is 1" diameter but it could be made from about any size. It has a handle so I can hold it up for a fast weld were even my clamp would have worked. Or I can reach around the back of panels to weld a hole out in the middle. Works like a charm. It was free because I had the pipe sitting there but one quick trip to the hardware store and a few bucks (or less) and you can make one too.
Old 06-30-2007, 11:05 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
That's a cool idea. I think I saw it before but forgot
Cool meaning it won't get hot instantly
I suppose you could also use some flexable copper tubing and a long length bent just right could get snaked up inside blind panels for dechroming.
Old 06-30-2007, 11:51 AM
cboy's Avatar
Last journal entry: Finished
Cool little tool.
Always learning...and sharing what I've learned.
Welding info Kevin45 Body - Exterior 10 08-26-2011 08:09 AM
Cost for welding floorpans hot_rod_kid Garage - Tools 17 01-22-2005 12:00 PM
Low cost Gasser cpprint1 Introduce Yourself 1 12-27-2004 01:56 PM
low cost security system fat50 Garage - Tools 15 09-18-2004 09:30 PM
low cost sheet metal jackfrost51 Body - Exterior 3 05-09-2004 05:01 PM
