Low Cylinder Compression. Why? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2010, 02:31 PM
Wanna-be custom upholsterer
I have a 99 Chevy Suburban with the 5.7 Vortec (not LS style) with 140K on the Motor. Was getting a P0303 code (#3cyl miss-fire) and a rough idle but good driving performance. I had already done a Major TuneUp using all ACDelco Parts at 130K and I noticed #3 plug was Blacker w/burnt oil on it, but it was running fine. Started problem about 500mi ago and Intake Gasket was leaking coolant so that was all changed with Felpro PermaDry gaskets, Upper and Lower w/new intake bolts. Thought the injector/Poppet was plugged so I ran BG44 with an improvement in idle but not perfect. New Delco Plat plug is getting the same black/burnt oil on it now.
I did a compression test on the warmed up engine last night. Cyl#1=180 Cyl#3=90 Cyl#5=175. Squirted oil in the #3 cylinder and ran compression check 3 more timed. All 3 times, the Initial crank was a major jump and gradual increase for the next 4 cranks but only went to 95-100psi, so not the rings. I then put it back together and checked vacuum at the Power Brake booster port. 17.5 in/Hg and constant, no fluctuation at all. Hit the throttle wide open and snapped it shut. Vacuum went instantly to 0 in/hg then straight to 23 in/hg then settled solid at 17.5 in/hg, so valves should be good.
What the H%## am i missing here? Was thinking of running GM "Top Engine Cleaner" through the vacuum port to knock out any carbon as the Intake had a lot of EGR/PCV oil and carbon, and Lifter Valley had dry, hard carbon on the bottom of the Valley by the lifters that i had to scrape out. But I'm afraid of clogging the 2 CatConv and 3 O2 sensors on the truck.
Thanks for ANY help I can get!!!
Robert
Old 07-16-2010, 02:40 PM
what I would do is get a crankcase blowby gauge and check that. you said you put oil in the cylinders and it was the same comp. so maybe your blowing compression else where..(well obviously right).
try this, install a rad cap blowby unit, or make your own, and see what your reading there, maybe your puttin some compression in the cooling systerm.
Old 07-16-2010, 04:24 PM
406 bug's Avatar
9.82 @ 139mph
I would bet it is a result of your previous coolant leak. Cracked/warped head. I would do a leak down test. Good luck.
Old 07-16-2010, 05:34 PM
Robert
I would disagree with your conclusion of this test. 90 psi warm and "dry of oil" versus a major increase followed by 95-100 psi "wet with oil" is a pretty strong indicator that there is a cylinder wall sealing problem. A leakdown test was suggested, that's a good idea to narrow this down.
A side note, most intake to head sealing problems with the Gen I Vortec is the result of overheating the engine or a failure of the DexCool coolant. Did this happen?
Bogie
Old 07-16-2010, 05:39 PM
Compression on cyls 1&5 are 175psi, no coolant in oil or oil in coolant either. Another board suggested a sticking valve. What do you guys think?
Old 07-16-2010, 06:03 PM
A sticking or leaking valve will show on a vacuum test as a rhythmic drop in the vacuum every-time that cylinder comes around.
Your vacuum test also tends to support low compression. The dropped throttle test should come back to 26-29 inches with the mild cam in a Vortec; instead you're getting a 23 inches which is in the range requiring further investigation of the ring seal.
Bogie
Old 07-16-2010, 08:22 PM
T-bucket23's Avatar
Wiki Edits: 26
I would be willing to bet you have a burnt exhaust valve. It will cause low compression and will not effect the vacuum gauge that bad unless it is really bad. Where you have 100 lbs of compression, it cant be real bad.
Put some air pressure in that cylinder and see where it is leaking from
Chet
Old 07-16-2010, 09:21 PM
BOBCRMAN@aol.com's Avatar
I get a few of these per year. The over heat has caused the no. 3 intake valve to pull into the seat/port. Making a "Tulip" style looking valve that slowly leaks compression.
Or an eroded/cracked exhaust seat. Usually 3 or 5..exhaust...
Old 07-16-2010, 09:51 PM
Bogie
I will run a leakdown test, but when i said "Major Jump" i was using that phrase so no one thought each stroke was a slow build. It built compression the same way with or without oil in the cylinder and only varied 5psi, so i felt the rings were sealing OK.
The intake coolant leak was from the DexCool destroying the factory gaskets just like the 3.4L in my 2000 Impala did. The area of the intake gasket that sealed the rear coolant passage had almost turned to jelly. Thanks GM
Old 07-16-2010, 09:56 PM
What would this look like on a vacuum gauge? And would the rough idle randomly get better or worse on it's own? Lastly, if it is the valves, would I be better off getting New Vortec heads instead of rebuilding mine. I know the new factory heads are pretty damn cheap.
Old 07-21-2010, 09:03 AM
Did a Leak Down Test last night... Looks like an Exhaust Valve is leaking. Going to run some Goodwrench Top Engine Cleaner through it and see if its just carbon. Will keep you all posted.
Old 07-21-2010, 10:54 AM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Bogie
What ? Help me here . I didn't know Dex-cool caused gasket failure . I was going to put 150,000 mi coolant in my T-bucket after I flush the cooling system . Should I just use the old type permanent anti-freeze / coolant instead ?
Old 07-21-2010, 04:07 PM
GM had problems in the late 90's early 2000's with DexCool causing Intake Gaskets to fail. My 2000 3.4L Impala started Leaking at 60K. GM new it was a Defect because they Redesigned the Intake gasket and sold them to repair the leak. They didn't however Warranty the defect and wanted $780.00 to replace it. (did it myself w/$50 in parts). Common Problem on Gen2 SBC truck engines too. Just use FelPro gaskets and don't worry about it. Oh... watch for sludge.
Old 07-21-2010, 04:47 PM
LATECH's Avatar
T bucket has it right. Burned exhaust valve wont cause fluctuation in engine vacuum as it has little effect on the intake side of the cylinder. Putting oil in the cylinder in question is standard diagnostic routine and from the sounds of it proved rings ok thus with that to be absoluteley sure pull the valve cover and remove the rocker arms for #3 cylinder and charge it with air. ( leak down test). That will reveal how much the exhaust is leaking if needed pull the rockers off of a known good cylinder next to #3 and do the same so you have something to compare the leakage to .To perform a compression test properly ( although your presumptive results are fine in this case) one should pull all the plugs first and be sure to crank each cylinder an equal amount of times. Doing it on a cold engine is more precise to determine engine wear as when warmed up tolerances are a little tighter.Plus you wont have to use your best cuss words cause you fried your arm on a hot manifold.
Right cam for a 383? atomicrockerdude Engine 22 11-02-2009 12:13 AM
Low Compression KoTT Engine 7 06-25-2009 05:53 PM
What diff. does the compression make from high and low. wild_man84 Engine 1 05-17-2009 09:39 AM
351 windsor running rich ???? ve3ham Engine 19 08-08-2005 12:48 PM
how to keep low compression 67bird Engine 14 02-08-2004 07:10 PM
