Low Drag Calipers
Do they make a cast iron master with the quick stage valve for taking up pad clearance on low drag calipers or do you just run a 2# residual valve and the corvette cast cylinder not to mention I'm running a universal disc/drum proportioning valve.I value your expertise,THANX
I've tried a 2# before and they still took a bunch of pedal to take up the slack. I wound up using a 10# RPV on those front calipers and had no problems. Check the RPV, alot of them are nowhere close to their rating.
Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
Why would you want to run a big heavy cast iron master cylinder?
| Misfire at low RPM | 65Stanger | Engine | 9 | 07-29-2006 02:08 PM |
| Low Vacum No Brakes Please Help | Ray 1 | Engine | 5 | 07-19-2006 06:00 AM |
| How Low should I set the body over my chasis? | Quarter Flash | Hotrodding Basics | 6 | 04-21-2006 08:00 AM |
| 440 with a lot of low end torque... | 1972 new yorker | Engine | 3 | 02-23-2006 01:39 PM |
| 440 with a lot of low end torque... | 1972 new yorker | Engine | 0 | 02-23-2006 05:58 AM |
